Introdução
Follow this guide to replace the head strap clip on a Valve Index VR headset.
Power off and unplug your Index before you begin your repair.
O que você precisa
Insert the flat end of a spudger in between the bottom of the head strap clip and the head strap padding.
Pry up on the head strap clip until it is unclipped from the head strap.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Valve Index Answers community for help.
3 outras pessoas executaram este guia.
7Comentários do guia
Why are these clips so expensive? At $39.99 it's like someone mashed an extra 9 when putting in the price, the face gasket which is much larger, uses more material and is more robust costs less than half, even the power adapters are $5 cheaper.
Seems that the price has been corrected to $4.99
Dor -
Yeah. The price is seriously insane! Two smaller zipties fit through that opening just fine and cost me pennies and work better than that cheap plastic clip.
