Ir para o conteúdo principal
Valve Index Headset Eye Tube Gasket Replacement
O que você precisa
  1. Valve Index Headset Eye Tube Gasket Replacement, Adjust the eye tube relief: passo 1, imagem 1 %32
    • Twist the eye tube relief knob clockwise to fully extend it.
  2. Valve Index Headset Eye Tube Gasket Replacement, Remove the head strap clip: passo 2, imagem 1 %32 Valve Index Headset Eye Tube Gasket Replacement, Remove the head strap clip: passo 2, imagem 2 %32 Valve Index Headset Eye Tube Gasket Replacement, Remove the head strap clip: passo 2, imagem 3 %32
    • Insert the flat end of a spudger in between the bottom of the head strap clip and the head strap padding.
    • Pry up on the head strap clip until it is unclipped from the head strap.
    • To reinstall, first locate the recesses on the head strap for mounting the clip. Next, align the clip with the recesses, verify the tether cable is threaded through the clip, then simply press the clip back into place.
  3. Valve Index Headset Eye Tube Gasket Replacement, Remove the face gasket: passo 3, imagem 1 %32 Valve Index Headset Eye Tube Gasket Replacement, Remove the face gasket: passo 3, imagem 2 %32
    • Use your hand to gently pull the face gasket straight off of the headset.
    • The face gasket is held in place by four magnets that secure to screws in the face bezel.
    • Before installing a face gasket, ensure the four screws securing the face gasket bezel are installed. Otherwise, the face gasket will not stay in place.
  4. Valve Index Headset Eye Tube Gasket Replacement, Separate the cable from the head strap guide: passo 4, imagem 1 %32 Valve Index Headset Eye Tube Gasket Replacement, Separate the cable from the head strap guide: passo 4, imagem 2 %32
    • Use your fingers to pull the tether cable straight up off of the head strap cable guide.
  5. Valve Index Headset Eye Tube Gasket Replacement, Disconnect the tether cable: passo 5, imagem 1 %32 Valve Index Headset Eye Tube Gasket Replacement, Disconnect the tether cable: passo 5, imagem 2 %32
    • Pull the tether cable straight back out of the headset.
  6. Valve Index Headset Eye Tube Gasket Replacement, Remove the face gasket bezel: passo 6, imagem 1 %32
    • Use a T5 Torx screwdriver to remove the four 6.0 mm screws securing the face gasket bezel to the headset.
  7. Valve Index Headset Eye Tube Gasket Replacement: passo 7, imagem 1 %32 Valve Index Headset Eye Tube Gasket Replacement: passo 7, imagem 2 %32
    • Do not try and pry the face gasket bezel off, or you will damage the headset.
    • Grab the left edge of the face gasket bezel with your hand and slide it off of the headset.
    • During reassembly, visually verify the clips on the face gasket bezel are aligned with the headset before sliding it into place.
  8. Valve Index Headset Eye Tube Gasket Replacement: passo 8, imagem 1 %32 Valve Index Headset Eye Tube Gasket Replacement: passo 8, imagem 2 %32 Valve Index Headset Eye Tube Gasket Replacement: passo 8, imagem 3 %32
    • Repeat the previous step for the right side of the face gasket bezel.
    • Remove the face gasket bezel.
  9. Valve Index Headset Eye Tube Gasket Replacement, Remove the eye tube gasket: passo 9, imagem 1 %32 Valve Index Headset Eye Tube Gasket Replacement, Remove the eye tube gasket: passo 9, imagem 2 %32 Valve Index Headset Eye Tube Gasket Replacement, Remove the eye tube gasket: passo 9, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use a pair of tweezers to separate the left edge of the eye tube gasket from the headset.
    • Repeat the process for the right edge of the gasket.
    • During reassembly, make sure these holes are secured to the pegs on the headset before continuing.
  10. Valve Index Headset Eye Tube Gasket Replacement: passo 10, imagem 1 %32 Valve Index Headset Eye Tube Gasket Replacement: passo 10, imagem 2 %32 Valve Index Headset Eye Tube Gasket Replacement: passo 10, imagem 3 %32
    • Gently peel the eye tube gasket out of the headset.
    • The eye tube gasket is lightly adhered to the perimeter of the lenses. It should pull off easily.
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Valve Index Answers community for help.
Uma outra pessoa concluiu este guia.
Sam Omiotek
Membro desde: 02/25/19
73.429 Reputação
Autoria de 288 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 21
Últimos 30 dias: 107
Duração total: 3,615
