Ir para o conteúdo principal
VTech Write and Learn Creative Center Slider Replacement
O que você precisa
    1. VTech Write and Learn Creative Center Slider Replacement, Back Panel: passo 1, imagem 1 %32 VTech Write and Learn Creative Center Slider Replacement, Back Panel: passo 1, imagem 2 %32 VTech Write and Learn Creative Center Slider Replacement, Back Panel: passo 1, imagem 3 %32
      • Remove all eleven 9mm PH 2 Phillips screws securing the back of the case.
      Pergunte ao FixBot
      Comentar
    1. VTech Write and Learn Creative Center Slider Replacement, Slider: passo 2, imagem 1 %32
      • Remove the two 7mm PH 0 Phillips screws holding the slider to the slider handle.
      • The back of the slider will likely be coated in lubricant. Be careful not to make a mess.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
UMass Dartmouth, Team 1-2, Miles Spring 2016 Membro de UMass Dartmouth, Team 1-2, Miles Spring 2016
UMASSD-MILES-S16S1G2
3 Membros
Autoria de 12 guias
1Comentário do guia
This helps me alot. I haven't took my son's apart yet but my question is when you turn the slider to erase the board it will not erase. Do you think I will need to reattach something or is this fixable if take it apart? My email is caitlinmanderson0@gmail.com if you could kindly email me with any tips.
caitlin28901 - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 17
Ao todo: 762
