Ir para o conteúdo principal
VTech Write and Learn Creative Center Magnetic Screen Replacement
O que você precisa
    1. VTech Write and Learn Creative Center Magnetic Screen Replacement, Back Panel: passo 1, imagem 1 %32 VTech Write and Learn Creative Center Magnetic Screen Replacement, Back Panel: passo 1, imagem 2 %32 VTech Write and Learn Creative Center Magnetic Screen Replacement, Back Panel: passo 1, imagem 3 %32
      • Remove all eleven 9mm PH 2 Phillips screws securing the back of the case.
      Pergunte ao FixBot
      Comentar
    1. VTech Write and Learn Creative Center Magnetic Screen Replacement, Slider: passo 2, imagem 1 %32
      • Remove the two 7mm PH 0 Phillips screws holding the slider to the slider handle.
      • The back of the slider will likely be coated in lubricant. Be careful not to make a mess.
      Pergunte ao FixBot
      Comentar
    1. VTech Write and Learn Creative Center Magnetic Screen Replacement, Magnetic Screen: passo 3, imagem 1 %32 VTech Write and Learn Creative Center Magnetic Screen Replacement, Magnetic Screen: passo 3, imagem 2 %32
      • Remove the four 5mm PH 0 Phillips screws with 7mm heads holding the screen to the front of the case.
      Pergunte ao FixBot
      Comentar
    2. VTech Write and Learn Creative Center Magnetic Screen Replacement: passo 4, imagem 1 %32
      • Gently push the edges of the screen to remove it from the front case.
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
UMass Dartmouth, Team 1-2, Miles Spring 2016 Membro de UMass Dartmouth, Team 1-2, Miles Spring 2016
UMASSD-MILES-S16S1G2
3 Membros
Autoria de 24 guias
2Comentários do guia
Thank you for this! Do you have suggestions on how to fix the magnetic screen or get a replacement? I emailed the manufacturer (B. Toys for mine) and unfortunately they replied, “​We replace the full toy only, and do not offer the internal parts as replacements.“ But I don’t want all the rest of the plastic - I just want the magnets on the screen to properly appear and disappear. Instead, its like the magnetic powder floats so it’s constantly grey rather than clear or magnetized.
Katie - Responder Compartilhar
Hello I got the same issue i dont know how to fix ot of you mine is not even an year old but still get that grey screen plz help n let me know how to get rid of it Thankyou
wings_latif - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 33
Ao todo: 1,897
