Ir para o conteúdo principal
VTech VM3254 Monitor Circuit Board and Screen Replacement
O que você precisa
  1. VTech VM3254 Monitor Circuit Board and Screen Replacement, Battery: passo 1, imagem 1 %32 VTech VM3254 Monitor Circuit Board and Screen Replacement, Battery: passo 1, imagem 2 %32
    • Turn the monitor on its back, and remove the two 8 mm Phillips #0 case screws.
  2. VTech VM3254 Monitor Circuit Board and Screen Replacement: passo 2, imagem 1 %32 VTech VM3254 Monitor Circuit Board and Screen Replacement: passo 2, imagem 2 %32 VTech VM3254 Monitor Circuit Board and Screen Replacement: passo 2, imagem 3 %32
    • Use the iFixit Jimmy tool to begin removing the face of the monitor.
    • You may need to use an opening pick to hold the screen open as you move the Jimmy tool around all the edges of the device.
    • Once the screen has been separated, lift it from the case.
    • Be gentle while removing the screen. There are wires connected to the two pieces that may be damaged.
  3. VTech VM3254 Monitor Circuit Board and Screen Replacement: passo 3, imagem 1 %32 VTech VM3254 Monitor Circuit Board and Screen Replacement: passo 3, imagem 2 %32
    • Remove the four 8 mm Phillips #00 screws from the bracket that secures the battery.
    • Remove the bracket.
  4. VTech VM3254 Monitor Circuit Board and Screen Replacement: passo 4, imagem 1 %32 VTech VM3254 Monitor Circuit Board and Screen Replacement: passo 4, imagem 2 %32 VTech VM3254 Monitor Circuit Board and Screen Replacement: passo 4, imagem 3 %32
    • Gently remove the battery from its location.
    • Carefully disconnect the bundled cable connector from the circuit board.
  5. VTech VM3254 Monitor Circuit Board and Screen Replacement, Monitor Speaker: passo 5, imagem 1 %32 VTech VM3254 Monitor Circuit Board and Screen Replacement, Monitor Speaker: passo 5, imagem 2 %32
    • Remove the two 7 mm Phillips #00 screws from the speaker.
    • Carefully remove the speaker and its cords from the motherboard.
    • Handle gently to not break the motherboard or any other parts.
  6. VTech VM3254 Monitor Circuit Board and Screen Replacement: passo 6, imagem 1 %32
    • Desolder the wire connecting the speaker to the board.
  7. VTech VM3254 Monitor Circuit Board and Screen Replacement, Monitor Circuit Board and Screen: passo 7, imagem 1 %32 VTech VM3254 Monitor Circuit Board and Screen Replacement, Monitor Circuit Board and Screen: passo 7, imagem 2 %32
    • Remove the three 8 mm Phillips #00 screws.
    • Gently remove the screen and circuit board from the case.
  8. VTech VM3254 Monitor Circuit Board and Screen Replacement: passo 8, imagem 1 %32 VTech VM3254 Monitor Circuit Board and Screen Replacement: passo 8, imagem 2 %32
    • Remove the button assembly from the front of the screen unit.
    • Flip the screen unit back over and desolder the wire holding it to the case.
Conclusão
Christina Block
Membro desde: 02/09/23
375 Reputação
Autoria de 4 guias
Equipe
1Comentário do guia
Any source for replacement screens?
Rob Olivieri - Responder
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 55
Ao todo: 1,551
