Introdução
If the camera stand is cracked or it seems to be unbalanced, you may need to replace it with a new one. Below are the following steps to replace the camera stand in order for there to be balance and it to stand securely.
O que você precisa
Unscrew and remove the two 8 mm Phillips #0 screws from the bottom of the stand.
Use the Jimmy tool to open the stand.
Remove the bottom of the stand.
