Ir para o conteúdo principal
VTech VM3254 Battery Replacement
O que você precisa
    1. VTech VM3254 Battery Replacement, Battery: passo 1, imagem 1 %32 VTech VM3254 Battery Replacement, Battery: passo 1, imagem 2 %32
      • Turn the monitor on its back, and remove the two 8 mm Phillips #0 case screws.
      Pergunte ao FixBot
      Comentar
    2. VTech VM3254 Battery Replacement: passo 2, imagem 1 %32 VTech VM3254 Battery Replacement: passo 2, imagem 2 %32 VTech VM3254 Battery Replacement: passo 2, imagem 3 %32
      • Use the iFixit Jimmy tool to begin removing the face of the monitor.
      • You may need to use an opening pick to hold the screen open as you move the Jimmy tool around all the edges of the device.
      • Once the screen has been separated, lift it from the case.
      • Be gentle while removing the screen. There are wires connected to the two pieces that may be damaged.
      Pergunte ao FixBot
      Comentar
    3. VTech VM3254 Battery Replacement: passo 3, imagem 1 %32 VTech VM3254 Battery Replacement: passo 3, imagem 2 %32
      • Remove the four 8 mm Phillips #00 screws from the bracket that secures the battery.
      • Remove the bracket.
      Pergunte ao FixBot
      Comentar
    4. VTech VM3254 Battery Replacement: passo 4, imagem 1 %32 VTech VM3254 Battery Replacement: passo 4, imagem 2 %32 VTech VM3254 Battery Replacement: passo 4, imagem 3 %32
      • Gently remove the battery from its location.
      • Carefully disconnect the bundled cable connector from the circuit board.
      Pergunte ao FixBot
      Comentar
Conclusão
Jackson Meacham
Membro desde: 02/14/23
109 Reputação
Autoria de 1 guia
Equipe
1Comentário do guia
What is the battery that needs to be replaced called?
Aden Brooks - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 19
Últimos 30 dias: 77
Ao todo: 3,018
