Ir para o conteúdo principal
VTech Spin and Learn Color Flashlight Speaker Replacement
O que você precisa
  1. VTech Spin and Learn Color Flashlight Speaker Replacement, Battery Housing: passo 1, imagem 1 %32 VTech Spin and Learn Color Flashlight Speaker Replacement, Battery Housing: passo 1, imagem 2 %32
    • Locate the battery housing on the back of the flashlight as pictured.
    • Unscrew the single 8 mm Phillips #1 screw.
    • The screw will stay attached to the cover that will be removed.
    • Lift the battery housing cover to reveal the battery terminals. Remove the batteries.
  2. VTech Spin and Learn Color Flashlight Speaker Replacement, Speaker Housing: passo 2, imagem 1 %32 VTech Spin and Learn Color Flashlight Speaker Replacement, Speaker Housing: passo 2, imagem 2 %32 VTech Spin and Learn Color Flashlight Speaker Replacement, Speaker Housing: passo 2, imagem 3 %32
    • Locate the light blue speaker housing on the bottom of the flashlight.
    • Remove the three 6 mm Phillips #0 screws.
    • Once the screws have been removed, pull the housing away from the yellow body of the flashlight. Be careful not to disconnect the white wires from the speaker, unless speaker replacement is required.
  3. VTech Spin and Learn Color Flashlight Speaker Replacement, Speaker: passo 3, imagem 1 %32 VTech Spin and Learn Color Flashlight Speaker Replacement, Speaker: passo 3, imagem 2 %32 VTech Spin and Learn Color Flashlight Speaker Replacement, Speaker: passo 3, imagem 3 %32
    • Locate the wires connected to the speaker indicated by the red circles in image one.
    • Desolder the wires from the connection point circled in the second image. If you're unsure of how to use the soldering station, use iFixit's guide to soldering and desoldering to help.
    • Remove the 2 highlighted 4mm Phillips #0 screws in image three.
Conclusão
Nathaniel Troyer
Membro desde: 08/27/15
441 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 2-6, Blackwell Fall 2015 Membro de USF Tampa, Team 2-6, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G6
Membros da 3
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 393
