Ir para o conteúdo principal
VTech MobiGo Touch Learning System Screen Replacement
O que você precisa
    1. VTech MobiGo Touch Learning System Screen Replacement, Case: passo 1, imagem 1 %32
      • Remove the battery covers and the four batteries.
      Pergunte ao FixBot
      Comentar
    2. VTech MobiGo Touch Learning System Screen Replacement: passo 2, imagem 1 %32 VTech MobiGo Touch Learning System Screen Replacement: passo 2, imagem 2 %32
      • Remove the four plastic caps with a metal spudger to expose the 6.0 mm Philips JIS #0 case screws.
      • Remove the eight 6.0 mm JIS #0 case screws.
      Pergunte ao FixBot
      Comentar
    3. VTech MobiGo Touch Learning System Screen Replacement: passo 3, imagem 1 %32 VTech MobiGo Touch Learning System Screen Replacement: passo 3, imagem 2 %32
      • Using a plastic opening tool, separate the two pieces of the case carefully.
      Pergunte ao FixBot
      Comentar
    1. VTech MobiGo Touch Learning System Screen Replacement, Disassembling VTech MobiGo Touch Learning System Screen Enclosure: passo 4, imagem 1 %32
      • Remove the three 4.0 mm Philips J0 screws holding the "L" shaped brackets in place.
      Pergunte ao FixBot
      Comentar
    2. VTech MobiGo Touch Learning System Screen Replacement: passo 5, imagem 1 %32
      • Remove the three "L" shaped brackets and the spring.
      Pergunte ao FixBot
      Comentar
    3. VTech MobiGo Touch Learning System Screen Replacement: passo 6, imagem 1 %32
      • Flip the device over and remove the three 4.0 mm Philips J0 case screws.
      Pergunte ao FixBot
      Comentar
    4. VTech MobiGo Touch Learning System Screen Replacement: passo 7, imagem 1 %32
      • Separate the front and back of the case.
      • Use a plastic opening tool if necessary.
      Pergunte ao FixBot
      Comentar
    1. VTech MobiGo Touch Learning System Screen Replacement, Screen: passo 8, imagem 1 %32
      • Remove the 4 (3.4 mm Philips J0) screws holding the screen in
      Pergunte ao FixBot
      Comentar
    2. VTech MobiGo Touch Learning System Screen Replacement: passo 9, imagem 1 %32
      • Remove the black tape
      Pergunte ao FixBot
      Comentar
    3. VTech MobiGo Touch Learning System Screen Replacement: passo 10, imagem 1 %32
      • Remove the circuit board from the back of the screen.
      • The circuit board has double sided tape on the back side holding it to the screen.
      Pergunte ao FixBot
      Comentar
    4. VTech MobiGo Touch Learning System Screen Replacement: passo 11, imagem 1 %32
      • Peel the ribbon wire off of the circuit board. Now the screen should be free to remove.
      Pergunte ao FixBot
      Comentar
    5. VTech MobiGo Touch Learning System Screen Replacement: passo 12, imagem 1 %32
      • Resolder the new screens ribbon cable on the the circuit board.
      • Always be careful when soldering.
      Pergunte ao FixBot
      Comentar
Conclusão
Daniel Kresge
Membro desde: 09/01/15
409 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 8-3, Eyestone Fall 2015 Membro de USF Tampa, Team 8-3, Eyestone Fall 2015
USFT-EYESTONE-F15S8G3
3 Membros
Autoria de 17 guias
1Comentário do guia
mine i droped a rock on so i don’t get it
Jesse Eagan - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 43
Ao todo: 1,277
