Ir para o conteúdo principal
VTech MobiGo Touch Learning System Buttons Replacement
O que você precisa
    1. VTech MobiGo Touch Learning System Buttons Replacement, Case: passo 1, imagem 1 %32
      • Remove the battery covers and the four batteries.
      Pergunte ao FixBot
      Comentar
    2. VTech MobiGo Touch Learning System Buttons Replacement: passo 2, imagem 1 %32 VTech MobiGo Touch Learning System Buttons Replacement: passo 2, imagem 2 %32
      • Remove the four plastic caps with a metal spudger to expose the 6.0 mm Philips JIS #0 case screws.
      • Remove the eight 6.0 mm JIS #0 case screws.
      Pergunte ao FixBot
      Comentar
    3. VTech MobiGo Touch Learning System Buttons Replacement: passo 3, imagem 1 %32 VTech MobiGo Touch Learning System Buttons Replacement: passo 3, imagem 2 %32
      • Using a plastic opening tool, separate the two pieces of the case carefully.
      Pergunte ao FixBot
      Comentar
    1. VTech MobiGo Touch Learning System Buttons Replacement, Disassembling VTech MobiGo Touch Learning System Screen Enclosure: passo 4, imagem 1 %32
      • Remove the three 4.0 mm Philips J0 screws holding the "L" shaped brackets in place.
      Pergunte ao FixBot
      Comentar
    2. VTech MobiGo Touch Learning System Buttons Replacement: passo 5, imagem 1 %32
      • Remove the three "L" shaped brackets and the spring.
      Pergunte ao FixBot
      Comentar
    3. VTech MobiGo Touch Learning System Buttons Replacement: passo 6, imagem 1 %32
      • Flip the device over and remove the three 4.0 mm Philips J0 case screws.
      Pergunte ao FixBot
      Comentar
    4. VTech MobiGo Touch Learning System Buttons Replacement: passo 7, imagem 1 %32
      • Separate the front and back of the case.
      • Use a plastic opening tool if necessary.
      Pergunte ao FixBot
      Comentar
    1. VTech MobiGo Touch Learning System Buttons Replacement, Buttons: passo 8, imagem 1 %32
      • Remove 6 (3.8 mm Philips J0) screws holding the buttons in.
      Pergunte ao FixBot
      Comentar
    2. VTech MobiGo Touch Learning System Buttons Replacement: passo 9, imagem 1 %32 VTech MobiGo Touch Learning System Buttons Replacement: passo 9, imagem 2 %32
      • From here you can remove and replace the buttons.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Daniel Kresge
Membro desde: 09/01/15
409 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 8-3, Eyestone Fall 2015 Membro de USF Tampa, Team 8-3, Eyestone Fall 2015
USFT-EYESTONE-F15S8G3
3 Membros
Autoria de 17 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 19
Ao todo: 1,582
