Ir para o conteúdo principal
VTech Little Apps Tablet Battery Replacement
O que você precisa
    1. VTech Little Apps Tablet Battery Replacement, Battery: passo 1, imagem 1 %32
      • Remove the 9.9 mm screw covering the batteries with a PH1 driver head.
      Pergunte ao FixBot
      Comentar
    2. VTech Little Apps Tablet Battery Replacement: passo 2, imagem 1 %32
      • Use a plastic opening tool to pry the batteries out of their holding.
      • If replacing your batteries with new ones, be careful to insert them as indicated on the device.
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
USF Tampa, Team 2-6, Sullivan Spring 2016 Membro de USF Tampa, Team 2-6, Sullivan Spring 2016
USFT-SULLIVAN-S16S2G6
3 Membros
Autoria de 12 guias
1Comentário do guia
Hello. Thank you for this tutorial. Do you know where I can find this speaker because by typing the reference LYS208R, it is not easy to find a merchant site (I am from France)
Antoine D. - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 39
Ao todo: 1,767
