Ir para o conteúdo principal
VTech Learning Tunes Karaoke Volume Switch Replacement
O que você precisa
  1. VTech Learning Tunes Karaoke Volume Switch Replacement, Volume Switch: passo 1, imagem 1 %32
    • To remove the battery door, loosen the screw using a Flathead screwdriver.
    • A coin can also be used to loosen the screw.
  2. VTech Learning Tunes Karaoke Volume Switch Replacement: passo 2, imagem 1 %32 VTech Learning Tunes Karaoke Volume Switch Replacement: passo 2, imagem 2 %32
    • Remove the battery door and take out the batteries.
  3. VTech Learning Tunes Karaoke Volume Switch Replacement: passo 3, imagem 1 %32
    • Remove the six 9.5 mm Phillips #2 screws.
    • Remove the six 6.0 mm Phillips #2 screws.
  4. VTech Learning Tunes Karaoke Volume Switch Replacement: passo 4, imagem 1 %32 VTech Learning Tunes Karaoke Volume Switch Replacement: passo 4, imagem 2 %32
    • Gently pull up on the rear panel.
    • Be careful to not pull on the wire connections.
    • Gently place the back panel underneath the top panel with the tops facing each other, as shown in the picture.
  5. VTech Learning Tunes Karaoke Volume Switch Replacement: passo 5, imagem 1 %32 VTech Learning Tunes Karaoke Volume Switch Replacement: passo 5, imagem 2 %32
    • Using a Phillips PH1 screwdriver, remove the two 7.9 mm volume switch board screws.
  6. VTech Learning Tunes Karaoke Volume Switch Replacement: passo 6, imagem 1 %32
    • Once the screws have been removed, carefully move the volume switch board.
  7. VTech Learning Tunes Karaoke Volume Switch Replacement: passo 7, imagem 1 %32
Conclusão
Equipe
USF Tampa, Team 7-2, Cheng Spring 2016 Membro de USF Tampa, Team 7-2, Cheng Spring 2016
USFT-CHENG-S16S7G2
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 226
