Ir para o conteúdo principal
VTech Learning Tunes Karaoke Speaker Replacement
O que você precisa
  1. VTech Learning Tunes Karaoke Speaker  Replacement, Speaker: passo 1, imagem 1 %32
    • To remove the battery door, loosen the screw using a Flathead screwdriver.
    • A coin can also be used to loosen the screw.
    Pergunte ao FixBot
    Comentar
  2. VTech Learning Tunes Karaoke Speaker  Replacement: passo 2, imagem 1 %32 VTech Learning Tunes Karaoke Speaker  Replacement: passo 2, imagem 2 %32
    • Remove the battery door and take out the batteries.
    Pergunte ao FixBot
    Comentar
  3. VTech Learning Tunes Karaoke Speaker  Replacement: passo 3, imagem 1 %32
    • Remove the six 9.5 mm Phillips #2 screws.
    • Remove the six 6.0 mm Phillips #2 screws.
    Pergunte ao FixBot
    Comentar
  4. VTech Learning Tunes Karaoke Speaker  Replacement: passo 4, imagem 1 %32 VTech Learning Tunes Karaoke Speaker  Replacement: passo 4, imagem 2 %32
    • Gently pull up on the rear panel.
    • Be careful to not pull on the wire connections.
    • Carefully place the back panel underneath the top panel with the tops facing each other, as shown in the picture.
    Pergunte ao FixBot
    Comentar
  5. VTech Learning Tunes Karaoke Speaker  Replacement: passo 5, imagem 1 %32 VTech Learning Tunes Karaoke Speaker  Replacement: passo 5, imagem 2 %32
    • Remove two 7.9 mm Phillips #1 screws on the speaker cover.
    • After removing the screws, remove the black plastic speaker cover to expose the speaker.
    Pergunte ao FixBot
    Comentar
  6. VTech Learning Tunes Karaoke Speaker  Replacement: passo 6, imagem 1 %32
    • Desolder the speaker at the solder points to remove.
    • Learn more about soldering and desoldering connections here.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
USF Tampa, Team 7-2, Cheng Spring 2016 Membro de USF Tampa, Team 7-2, Cheng Spring 2016
USFT-CHENG-S16S7G2
4 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 14
Últimos 30 dias: 46
Ao todo: 1,052
