Ir para o conteúdo principal
VTech Learning Tunes Karaoke Mode Selector Replacement
O que você precisa
  1. VTech Learning Tunes Karaoke Mode Selector Replacement, Mode Selector: passo 1, imagem 1 %32
    • To remove the battery door, loosen the 4mm Flathead screw.
    • A coin can also be used to loosen the screw.
    Pergunte ao FixBot
    Comentar
  2. VTech Learning Tunes Karaoke Mode Selector Replacement: passo 2, imagem 1 %32 VTech Learning Tunes Karaoke Mode Selector Replacement: passo 2, imagem 2 %32
    • Remove the battery door and take out the batteries.
    Pergunte ao FixBot
    Comentar
  3. VTech Learning Tunes Karaoke Mode Selector Replacement: passo 3, imagem 1 %32
    • Remove the six 9.5 mm Phillips #2 screws.
    • Remove the six 6.0 mm Phillips #2 screws.
    Pergunte ao FixBot
    Comentar
  4. VTech Learning Tunes Karaoke Mode Selector Replacement: passo 4, imagem 1 %32 VTech Learning Tunes Karaoke Mode Selector Replacement: passo 4, imagem 2 %32
    • Gently pull up on the rear panel.
    • Be careful to not pull on the wire connections.
    • Gently place the back panel underneath the top panel with the tops facing each other, as shown in the picture.
    Pergunte ao FixBot
    Comentar
  5. VTech Learning Tunes Karaoke Mode Selector Replacement: passo 5, imagem 1 %32
    • Remove the two 7.9 mm Phillips #1 mode switch board screws.
    Pergunte ao FixBot
    Comentar
  6. VTech Learning Tunes Karaoke Mode Selector Replacement: passo 6, imagem 1 %32 VTech Learning Tunes Karaoke Mode Selector Replacement: passo 6, imagem 2 %32
    • Once the screws have been removed, carefully move the mode switch board to expose the mode switch assembly underneath.
    Pergunte ao FixBot
    Comentar
  7. VTech Learning Tunes Karaoke Mode Selector Replacement: passo 7, imagem 1 %32 VTech Learning Tunes Karaoke Mode Selector Replacement: passo 7, imagem 2 %32
    • Using a Philips #1 screwdriver, remove the two 5.6 mm screws on the switch.
    • Once the screws have been removed, you can easily remove the mode switch.
    Pergunte ao FixBot
    Comentar
Conclusão
Adam Chaberek
Membro desde: 02/09/16
137 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 7-2, Cheng Spring 2016 Membro de USF Tampa, Team 7-2, Cheng Spring 2016
USFT-CHENG-S16S7G2
4 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 33
Ao todo: 625
