Ir para o conteúdo principal
VTech Kidizoom Camera Connect Shutter Button Replacement
O que você precisa
  1. VTech Kidizoom Camera Connect Shutter Button Replacement, Front Case: passo 1, imagem 1 %32 VTech Kidizoom Camera Connect Shutter Button Replacement, Front Case: passo 1, imagem 2 %32
    • Remove batteries and SD card before beginning disassembly!
    • Locate the four plastic screw covers denoted by the markers and gently pry them up with the metal spudger.
    Pergunte ao FixBot
    Comentar
  2. VTech Kidizoom Camera Connect Shutter Button Replacement: passo 2, imagem 1 %32 VTech Kidizoom Camera Connect Shutter Button Replacement: passo 2, imagem 2 %32
    • Remove all four (11mm) screws with the Philips #0 screwdriver.
    Pergunte ao FixBot
    Comentar
  3. VTech Kidizoom Camera Connect Shutter Button Replacement: passo 3, imagem 1 %32 VTech Kidizoom Camera Connect Shutter Button Replacement: passo 3, imagem 2 %32 VTech Kidizoom Camera Connect Shutter Button Replacement: passo 3, imagem 3 %32
    • Remove the two battery cartridges located on the underside of the camera.
    • Once cartridges are removed, use the metal spudger to pry open the top, bottom, and both sides of the camera.
    Pergunte ao FixBot
    Comentar
  4. VTech Kidizoom Camera Connect Shutter Button Replacement: passo 4, imagem 1 %32
    • Beware of the two black viewfinder lens falling out as you pry open the device!
    • The device should now be open and ready for further repair and/or replacement parts.
    Pergunte ao FixBot
    Comentar
  5. VTech Kidizoom Camera Connect Shutter Button Replacement, Shutter Button: passo 5, imagem 1 %32
    • Remove the purple plastic that covers the button and circuit board. It should slide right out from the slot it sits in.
    Pergunte ao FixBot
    Comentar
  6. VTech Kidizoom Camera Connect Shutter Button Replacement: passo 6, imagem 1 %32
    • Unsolder wires connected to the right side of the circuit board. Pull the wires to the side.
    Pergunte ao FixBot
    Comentar
  7. VTech Kidizoom Camera Connect Shutter Button Replacement: passo 7, imagem 1 %32 VTech Kidizoom Camera Connect Shutter Button Replacement: passo 7, imagem 2 %32
    • The button/circuit board should be loose now. Gently pull out the button/circuit board to remove it from the device.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
USF Tampa, Team 6-4, Eyestone Spring 2016 Membro de USF Tampa, Team 6-4, Eyestone Spring 2016
USFT-EYESTONE-S16S6G4
4 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 52
Ao todo: 1,577
