Ir para o conteúdo principal
VTech Kidizoom Action Cam Buttons Replacement
O que você precisa
    1. VTech Kidizoom Action Cam Buttons Replacement, Display Assembly: passo 1, imagem 1 %32
      • Make sure that the master power switch is set to the (O) position.
      Pergunte ao FixBot
      Comentar
    2. VTech Kidizoom Action Cam Buttons Replacement: passo 2, imagem 1 %32
      • Using a plastic opening tool, gently pry off the circular plating over the camera lens.
      • The circular plating is held by a mild adhesive. It will not be necessary to replace this adhesive during the reassembly process.
      Pergunte ao FixBot
      Comentar
    3. VTech Kidizoom Action Cam Buttons Replacement: passo 3, imagem 1 %32
      Ferramenta utilizada neste passo:
      Magnetic Project Mat
      $19.95
      • Use a #0 screwdriver to remove the two 2.5mm Phillips head screws located on the second layer of plating.
      • Remove the second layer of plating previously held down by the screws by gripping it with your fingers and pulling upward.
      • As there will be many screws being removed from the device, we recommend using a magnetic device such as the iFixit Magnetic Project Mat.
      Pergunte ao FixBot
      Comentar
    4. VTech Kidizoom Action Cam Buttons Replacement: passo 4, imagem 1 %32
      • Pry off the transparent plating and paper design using a plastic opening tool.
      Pergunte ao FixBot
      Comentar
    5. VTech Kidizoom Action Cam Buttons Replacement: passo 5, imagem 1 %32
      • Unscrew the (4) 2.5mm Phillips head screws from the third layer of plating using a #0 screwdriver.
      Pergunte ao FixBot
      Comentar
    6. VTech Kidizoom Action Cam Buttons Replacement: passo 6, imagem 1 %32
      • Turn the camera around and gently remove the plating that surrounds the LCD screen by grasping it with your fingers and pulling away from the device.
      Pergunte ao FixBot
      Comentar
    7. VTech Kidizoom Action Cam Buttons Replacement: passo 7, imagem 1 %32 VTech Kidizoom Action Cam Buttons Replacement: passo 7, imagem 2 %32 VTech Kidizoom Action Cam Buttons Replacement: passo 7, imagem 3 %32
      • Use the plastic opening tool to lift the LCD screen, including the purple casing and set it aside, revealing the motherboard and connector ribbon.
      • Exercise caution while performing this step, as any excessive pulling may tear the connector ribbon from the motherboard.
      Pergunte ao FixBot
      Comentar
    1. VTech Kidizoom Action Cam Buttons Replacement, Buttons: passo 8, imagem 1 %32 VTech Kidizoom Action Cam Buttons Replacement, Buttons: passo 8, imagem 2 %32
      • Push out the buttons that you wish to take out, and replace them with the new buttons.
      • Cleaning the buttons may fix the issue of sticky buttons, and a replacement may not be necessary.
      Pergunte ao FixBot
      Comentar
Conclusão
3 outras pessoas executaram este guia.
Equipe
USF Tampa, Team 3-5, Sullivan Spring 2016 Membro de USF Tampa, Team 3-5, Sullivan Spring 2016
USFT-SULLIVAN-S16S3G5
3 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 26
Ao todo: 3,055
