Ir para o conteúdo principal
VTech InnoTab Max Screen Replacement
O que você precisa
    1. VTech InnoTab Max Screen Replacement, Cover: passo 1, imagem 1 %32 VTech InnoTab Max Screen Replacement, Cover: passo 1, imagem 2 %32 VTech InnoTab Max Screen Replacement, Cover: passo 1, imagem 3 %32
      • Remove all screw caps from the back panel using a metal spudger.
      Pergunte ao FixBot
      Comentar
    2. VTech InnoTab Max Screen Replacement: passo 2, imagem 1 %32 VTech InnoTab Max Screen Replacement: passo 2, imagem 2 %32 VTech InnoTab Max Screen Replacement: passo 2, imagem 3 %32
      • Next remove all of the now uncovered screws.
      • If there is a cartridge in the device make sure to remove it.
      Pergunte ao FixBot
      Comentar
    3. VTech InnoTab Max Screen Replacement: passo 3, imagem 1 %32 VTech InnoTab Max Screen Replacement: passo 3, imagem 2 %32
      • Now that all of the screws have been removed, pry the back cover off using a plastic opening tool.
      Pergunte ao FixBot
      Comentar
    4. VTech InnoTab Max Screen Replacement: passo 4, imagem 1 %32 VTech InnoTab Max Screen Replacement: passo 4, imagem 2 %32
      • Here you can see the back cover has been fully removed and you can now access the front cover.
      • To remove the front cover, remove the springs holding the pictured brackets in place, then pull it away.
      Pergunte ao FixBot
      Comentar
    1. VTech InnoTab Max Screen Replacement, Battery: passo 5, imagem 1 %32
      • Once the back cover is removed the battery will be located in the bottom right as you can see in the image to the right.
      Pergunte ao FixBot
      Comentar
    2. VTech InnoTab Max Screen Replacement: passo 6, imagem 1 %32 VTech InnoTab Max Screen Replacement: passo 6, imagem 2 %32 VTech InnoTab Max Screen Replacement: passo 6, imagem 3 %32
      Ferramenta utilizada neste passo:
      Plastic Cards
      $2.99
      • Remove the tape holding down the wires, and carefully pry the battery off of the base of the device.
      • Pry carefully to avoid damaging the battery. The battery may start to bend slightly, this is normal and not a cause for concern.
      • It is best to use a plastic card or nylon spudger to remove the battery. Metal tools can puncture a battery, potentially causing a fire.
      Pergunte ao FixBot
      Comentar
    3. VTech InnoTab Max Screen Replacement: passo 7, imagem 1 %32 VTech InnoTab Max Screen Replacement: passo 7, imagem 2 %32 VTech InnoTab Max Screen Replacement: passo 7, imagem 3 %32
      • Now that the battery is free to be moved, unplug the wire connecting the battery to the motherboard.
      Pergunte ao FixBot
      Comentar
    4. VTech InnoTab Max Screen Replacement: passo 8, imagem 1 %32
      • The battery is now fully disconnected.
      Pergunte ao FixBot
      Comentar
    1. VTech InnoTab Max Screen Replacement, Screen: passo 9, imagem 1 %32 VTech InnoTab Max Screen Replacement, Screen: passo 9, imagem 2 %32
      • In order to unlock the screen you need to remove the 4 pins that can be seen in the picture.
      • To remove simply just turn and pull them out. Use a metal or nylon spudger if they are too small to grip.
      Pergunte ao FixBot
      Comentar
    2. VTech InnoTab Max Screen Replacement: passo 10, imagem 1 %32 VTech InnoTab Max Screen Replacement: passo 10, imagem 2 %32 VTech InnoTab Max Screen Replacement: passo 10, imagem 3 %32
      • Once the pins are removed the screen should be loose from the frame and only connected by the brown film pictured.
      Pergunte ao FixBot
      Comentar
    3. VTech InnoTab Max Screen Replacement: passo 11, imagem 1 %32 VTech InnoTab Max Screen Replacement: passo 11, imagem 2 %32 VTech InnoTab Max Screen Replacement: passo 11, imagem 3 %32
      • In order to completely remove the screen you need to unclip the film from the motherboard by simply using a pair of tweezers and gently pulling.
      • Be careful not to tear the film when pulling.
      Pergunte ao FixBot
      Comentar
    4. VTech InnoTab Max Screen Replacement: passo 12, imagem 1 %32 VTech InnoTab Max Screen Replacement: passo 12, imagem 2 %32
      • Once unclipped from the motherboard the screen should be entirely free from the device
      Pergunte ao FixBot
      Comentar
Conclusão
4 outras pessoas executaram este guia.
Equipe
USF Tampa, Team S5-G5, Lacy Spring 2017 Membro de USF Tampa, Team S5-G5, Lacy Spring 2017
USFT-LACY-S17S5G5
3 Membros
Autoria de 15 guias
5Comentários do guia
Where can I buy a screen
Damien Hennigan - Responder Compartilhar
Where can I buy a screen? Can't find any sites that sell the innotab Max screens.
i can not seem to find a replacement screen online, where can i buy one? Innotab Max from Vtech… HELP please..
fanny_muller - Responder Compartilhar
Hello, where can i buy a KIDICOM MAX Rose Screen. Our daughter here is broken!.thanks a lot!
hans.depre@gmail.com
Hans Depre - Responder Compartilhar
bonjour je cherche a raplasser l ecran du kidicom max car le mien ne salume plus pas merci
theobald - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 31
Ao todo: 5,860
