Ir para o conteúdo principal
VTech InnoTab Max Camera Replacement
O que você precisa
    1. VTech InnoTab Max Camera Replacement, Cover: passo 1, imagem 1 %32 VTech InnoTab Max Camera Replacement, Cover: passo 1, imagem 2 %32 VTech InnoTab Max Camera Replacement, Cover: passo 1, imagem 3 %32
      • Remove all screw caps from the back panel using a metal spudger.
      Pergunte ao FixBot
      Comentar
    2. VTech InnoTab Max Camera Replacement: passo 2, imagem 1 %32 VTech InnoTab Max Camera Replacement: passo 2, imagem 2 %32 VTech InnoTab Max Camera Replacement: passo 2, imagem 3 %32
      • Next remove all of the now uncovered screws.
      • If there is a cartridge in the device make sure to remove it.
      Pergunte ao FixBot
      Comentar
    3. VTech InnoTab Max Camera Replacement: passo 3, imagem 1 %32 VTech InnoTab Max Camera Replacement: passo 3, imagem 2 %32
      • Now that all of the screws have been removed, pry the back cover off using a plastic opening tool.
      Pergunte ao FixBot
      Comentar
    4. VTech InnoTab Max Camera Replacement: passo 4, imagem 1 %32 VTech InnoTab Max Camera Replacement: passo 4, imagem 2 %32
      • Here you can see the back cover has been fully removed and you can now access the front cover.
      • To remove the front cover, remove the springs holding the pictured brackets in place, then pull it away.
      Pergunte ao FixBot
      Comentar
    1. VTech InnoTab Max Camera Replacement, Camera: passo 5, imagem 1 %32
      • The camera is not held down by anything, so simply remove it from it's spot to prepare for unplugging it.
      Pergunte ao FixBot
      Comentar
    2. VTech InnoTab Max Camera Replacement: passo 6, imagem 1 %32 VTech InnoTab Max Camera Replacement: passo 6, imagem 2 %32
      • Carefully remove the wire connecting the camera to the motherboard, using a tool to grip it if needed.
      • Be careful to only pull from the end of the connector (closest to the motherboard), as the strip is easy to tear.
      Pergunte ao FixBot
      Comentar
    3. VTech InnoTab Max Camera Replacement: passo 7, imagem 1 %32
      • The camera is now removed completely removed from the device.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
USF Tampa, Team S5-G5, Lacy Spring 2017 Membro de USF Tampa, Team S5-G5, Lacy Spring 2017
USFT-LACY-S17S5G5
3 Membros
Autoria de 15 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 33
Ao todo: 862
