Ir para o conteúdo principal
VTech InnoTab 2 Headphone Jack Replacement
O que você precisa
  1. VTech InnoTab 2 Headphone Jack Replacement, Battery: passo 1, imagem 1 %32 VTech InnoTab 2 Headphone Jack Replacement, Battery: passo 1, imagem 2 %32 VTech InnoTab 2 Headphone Jack Replacement, Battery: passo 1, imagem 3 %32
    • Apply slight pressure and slide the button above the battery cabinet to the right to open.
    • Remove battery cabinet cover by sliding away from the center of device.
    • This device requires 4AA batteries to function without the AC adaptor.
  2. VTech InnoTab 2 Headphone Jack Replacement, Back Panel: passo 2, imagem 1 %32 VTech InnoTab 2 Headphone Jack Replacement, Back Panel: passo 2, imagem 2 %32 VTech InnoTab 2 Headphone Jack Replacement, Back Panel: passo 2, imagem 3 %32
    • Remove all nine plastic caps from the back of the device using the plastic opening tool.
    • These covers are made of hard plastic so they may be difficult to remove.
  3. VTech InnoTab 2 Headphone Jack Replacement: passo 3, imagem 1 %32 VTech InnoTab 2 Headphone Jack Replacement: passo 3, imagem 2 %32 VTech InnoTab 2 Headphone Jack Replacement: passo 3, imagem 3 %32
    • Remove the hard rubber tab located by the cartridge slot using the plastic opening tool.
    • Be careful not to apply excessive force.
    • Once the rubber tab is removed unscrew the single 7 mm screw using a J0 screwdriver.
  4. VTech InnoTab 2 Headphone Jack Replacement: passo 4, imagem 1 %32 VTech InnoTab 2 Headphone Jack Replacement: passo 4, imagem 2 %32
    • Remove all ten 7mm screws from the back panel of the device using a JO bit screwdriver.
    • Do not use excessive force while removing the screws to prevent damaging the plastic case.
  5. VTech InnoTab 2 Headphone Jack Replacement: passo 5, imagem 1 %32 VTech InnoTab 2 Headphone Jack Replacement: passo 5, imagem 2 %32
    • Using the plastic opening tool, detach the back plate from the front piece.
    • Do not use excessive force. If the back plate does not gently come on double check that all screws were removed.
    • Once the back panel is removed, you will be able to see the motherboard and other components within the device.
  6. VTech InnoTab 2 Headphone Jack Replacement, Headphone Jack: passo 6, imagem 1 %32 VTech InnoTab 2 Headphone Jack Replacement, Headphone Jack: passo 6, imagem 2 %32 VTech InnoTab 2 Headphone Jack Replacement, Headphone Jack: passo 6, imagem 3 %32
    • Remove the two 7 mm screws from the left bumper of the device using a JO screwdriver.
    • Be careful not to pull to hard when removing the bumper to avoid damage to the circuit.
  7. VTech InnoTab 2 Headphone Jack Replacement: passo 7, imagem 1 %32 VTech InnoTab 2 Headphone Jack Replacement: passo 7, imagem 2 %32 VTech InnoTab 2 Headphone Jack Replacement: passo 7, imagem 3 %32
    • Use your fingers to gently remove the headphone jack.
    • De-solder the points shown to fully remove the headphone jack from the motherboard.
    • A soldering guide offered by IFIXIT can be found here Soldering Skills
Conclusão
Roberto Valdes
Membro desde: 10/18/17
302 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team S1-G85, Cagle Fall 2017 Membro de USF Tampa, Team S1-G85, Cagle Fall 2017
USFT-CAGLE-F17S1G85
Membros da 2
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 7
Duração total: 219
