Introdução
Tired of taking pictures with poor quality on your VTech InnoTab 2. Then follow our quick guide to walk you through replacing a faulty camera on your VTech InnoTab 2.
O que você precisa
Apply slight pressure and slide the button above the battery cabinet to the right to open.
Remove battery cabinet cover by sliding away from the center of device.
Remove all nine plastic caps from the back of the device using the plastic opening tool.
Using the tip of your finger, carefully pull the clip upwards to release the camera connection from the motherboard.
Attach the replacement camera and lower the latch until a click sound can be heard.
