Ir para o conteúdo principal
VTech InnoTab 2 Camera Replacement
O que você precisa
  1. VTech InnoTab 2 Camera Replacement, Battery: passo 1, imagem 1 %32 VTech InnoTab 2 Camera Replacement, Battery: passo 1, imagem 2 %32 VTech InnoTab 2 Camera Replacement, Battery: passo 1, imagem 3 %32
    • Apply slight pressure and slide the button above the battery cabinet to the right to open.
    • Remove battery cabinet cover by sliding away from the center of device.
    • This device requires 4AA batteries to function without the AC adaptor.
    Pergunte ao FixBot
    Comentar
  2. VTech InnoTab 2 Camera Replacement, Back Panel: passo 2, imagem 1 %32 VTech InnoTab 2 Camera Replacement, Back Panel: passo 2, imagem 2 %32 VTech InnoTab 2 Camera Replacement, Back Panel: passo 2, imagem 3 %32
    • Remove all nine plastic caps from the back of the device using the plastic opening tool.
    • These covers are made of hard plastic so they may be difficult to remove.
    Pergunte ao FixBot
    Comentar
  3. VTech InnoTab 2 Camera Replacement: passo 3, imagem 1 %32 VTech InnoTab 2 Camera Replacement: passo 3, imagem 2 %32 VTech InnoTab 2 Camera Replacement: passo 3, imagem 3 %32
    • Remove the hard rubber tab located by the cartridge slot using the plastic opening tool.
    • Be careful not to apply excessive force.
    • Once the rubber tab is removed unscrew the single 7 mm screw using a J0 screwdriver.
    Pergunte ao FixBot
    Comentar
  4. VTech InnoTab 2 Camera Replacement: passo 4, imagem 1 %32 VTech InnoTab 2 Camera Replacement: passo 4, imagem 2 %32
    • Remove all ten 7mm screws from the back panel of the device using a JO bit screwdriver.
    • Do not use excessive force while removing the screws to prevent damaging the plastic case.
    Pergunte ao FixBot
    Comentar
  5. VTech InnoTab 2 Camera Replacement: passo 5, imagem 1 %32 VTech InnoTab 2 Camera Replacement: passo 5, imagem 2 %32
    • Using the plastic opening tool, detach the back plate from the front piece.
    • Do not use excessive force. If the back plate does not gently come on double check that all screws were removed.
    • Once the back panel is removed, you will be able to see the motherboard and other components within the device.
    Pergunte ao FixBot
    Comentar
  6. VTech InnoTab 2 Camera Replacement, Camera: passo 6, imagem 1 %32 VTech InnoTab 2 Camera Replacement, Camera: passo 6, imagem 2 %32 VTech InnoTab 2 Camera Replacement, Camera: passo 6, imagem 3 %32
    • Using the tip of your finger, carefully pull the clip upwards to release the camera connection from the motherboard.
    • The connection to the camera is located on top side of the devices motherboard.
    • Pulling the camera while the connection to the motherboard is still intact can cause damage to the circuit board.
    • Attach the replacement camera and lower the latch until a click sound can be heard.
    Pergunte ao FixBot
    Comentar
Conclusão
Roberto Valdes
Membro desde: 10/18/17
302 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team S1-G85, Cagle Fall 2017 Membro de USF Tampa, Team S1-G85, Cagle Fall 2017
USFT-CAGLE-F17S1G85
2 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 33
Ao todo: 664
