Introdução
During this guide, the base will need to be disassembled and then desolder the charging wire connections.
O que você precisa
Remove the four Phillips #0 screws (9.4mm) located at the bottom of the phone on the back side of the base.
Heat up solder joint on the circuit board where the charging wires are connected. Note: This is the CRD- and CRD+ terminals.
Uma outra pessoa concluiu este guia.
