Ir para o conteúdo principal
VTech Baby's Learning Laptop Volume Switch Replacement
O que você precisa
    1. VTech Baby's Learning Laptop Volume Switch  Replacement, Battery and Rear Panel: passo 1, imagem 1 %32
      • To remove the battery door, loosen the screw shown using a Phillips #2 screwdriver.
      • A coin can also be used to loosen the screw.
      Pergunte ao FixBot
      Comentar
    2. VTech Baby's Learning Laptop Volume Switch  Replacement: passo 2, imagem 1 %32
      • Remove the battery door.
      • Take out the batteries.
      Pergunte ao FixBot
      Comentar
    3. VTech Baby's Learning Laptop Volume Switch  Replacement: passo 3, imagem 1 %32
      • Remove the rear panel screws using a Phillips #2 screwdriver.
      • Two 21.6mm (Long)
      • One 9.8mm (Short)
      • Five 13.8mm (Medium)
      Pergunte ao FixBot
      Comentar
    4. VTech Baby's Learning Laptop Volume Switch  Replacement: passo 4, imagem 1 %32 VTech Baby's Learning Laptop Volume Switch  Replacement: passo 4, imagem 2 %32
      • Gently pull up on the rear panel.
      • Be careful not to pull on the wire connections.
      • Rest the laptop open on the table.
      Pergunte ao FixBot
      Comentar
    1. VTech Baby's Learning Laptop Volume Switch  Replacement, Volume Switch: passo 5, imagem 1 %32
      • Flip your device so the bottom panel is facing up.
      Pergunte ao FixBot
      Comentar
    2. VTech Baby's Learning Laptop Volume Switch  Replacement: passo 6, imagem 1 %32 VTech Baby's Learning Laptop Volume Switch  Replacement: passo 6, imagem 2 %32
      • Use a Phillips #2 screwdriver to remove the two 7.7mm screws on the volume switch.
      Pergunte ao FixBot
      Comentar
    3. VTech Baby's Learning Laptop Volume Switch  Replacement: passo 7, imagem 1 %32 VTech Baby's Learning Laptop Volume Switch  Replacement: passo 7, imagem 2 %32
      • Remove the volume switch.
      • Be careful not damage the wiring.
      Pergunte ao FixBot
      Comentar
Conclusão
Jordan Smith
Membro desde: 09/03/15
210 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 12-2, Blackwell Fall 2015 Membro de USF Tampa, Team 12-2, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G2
4 Membros
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 41
Ao todo: 1,212
