Ir para o conteúdo principal
VTech Baby's Learning Laptop Buttons Replacement
O que você precisa
    1. VTech Baby's Learning Laptop Buttons Replacement, Battery and Rear Panel: passo 1, imagem 1 %32
      • To remove the battery door, loosen the screw shown using a Phillips #2 screwdriver.
      • A coin can also be used to loosen the screw.
      Pergunte ao FixBot
      Comentar
    2. VTech Baby's Learning Laptop Buttons Replacement: passo 2, imagem 1 %32
      • Remove the battery door.
      • Take out the batteries.
      Pergunte ao FixBot
      Comentar
    3. VTech Baby's Learning Laptop Buttons Replacement: passo 3, imagem 1 %32
      • Remove the rear panel screws using a Phillips #2 screwdriver.
      • Two 21.6mm (Long)
      • One 9.8mm (Short)
      • Five 13.8mm (Medium)
      Pergunte ao FixBot
      Comentar
    4. VTech Baby's Learning Laptop Buttons Replacement: passo 4, imagem 1 %32 VTech Baby's Learning Laptop Buttons Replacement: passo 4, imagem 2 %32
      • Gently pull up on the rear panel.
      • Be careful not to pull on the wire connections.
      • Rest the laptop open on the table.
      Pergunte ao FixBot
      Comentar
    1. VTech Baby's Learning Laptop Buttons Replacement, Buttons: passo 5, imagem 1 %32
      • Using a Phillips #0 screwdriver remove the two 6.0mm screws.
      Pergunte ao FixBot
      Comentar
    2. VTech Baby's Learning Laptop Buttons Replacement: passo 6, imagem 1 %32 VTech Baby's Learning Laptop Buttons Replacement: passo 6, imagem 2 %32
      • Lift up on the board and set it aside.
      • Movement of the board will be limited. Be careful not to damage the connection to the motherboard.
      Pergunte ao FixBot
      Comentar
    3. VTech Baby's Learning Laptop Buttons Replacement: passo 7, imagem 1 %32
      • Remove each button and button contact.
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
USF Tampa, Team 12-2, Blackwell Fall 2015 Membro de USF Tampa, Team 12-2, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G2
4 Membros
Autoria de 35 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 24
Ao todo: 1,318
