Ir para o conteúdo principal
VENSTAR Taco Speaker Replacement Replacement
O que você precisa
  1. VENSTAR Taco Speaker Replacement Replacement, VENSTAR Taco Disassembly: passo 1, imagem 1 %32 VENSTAR Taco Speaker Replacement Replacement, VENSTAR Taco Disassembly: passo 1, imagem 2 %32 VENSTAR Taco Speaker Replacement Replacement, VENSTAR Taco Disassembly: passo 1, imagem 3 %32
    • Starting with the Taco on its side, use the plastic opening tool to pop off the outer casing near the base.
    • The base labeled "VENSTAR TACO" is glued. Be careful separating the two sides of the device.
    Pergunte ao FixBot
    Comentar
  2. VENSTAR Taco Speaker Replacement Replacement: passo 2, imagem 1 %32 VENSTAR Taco Speaker Replacement Replacement: passo 2, imagem 2 %32
    • Repeat the previous step on the opposite side to remove the other outer casing.
    Pergunte ao FixBot
    Comentar
  3. VENSTAR Taco Speaker Replacement Replacement: passo 3, imagem 1 %32 VENSTAR Taco Speaker Replacement Replacement: passo 3, imagem 2 %32
    Ferramenta utilizada neste passo:
    Phillips #0 Screwdriver
    $5.49
    • Using a Phillips PH0 3 mm-bit screwdriver, remove the six screws on the inner layer of the Taco.
    • The screws are small and can get stuck. Use tweezers to pull them out if you are having trouble.
    Pergunte ao FixBot
    Comentar
  4. VENSTAR Taco Speaker Replacement Replacement: passo 4, imagem 1 %32 VENSTAR Taco Speaker Replacement Replacement: passo 4, imagem 2 %32
    • From the same side you just unscrewed, use a plastic opening tool to unwedge the inner cover on both sides of the base.
    Pergunte ao FixBot
    Comentar
  5. VENSTAR Taco Speaker Replacement Replacement: passo 5, imagem 1 %32 VENSTAR Taco Speaker Replacement Replacement: passo 5, imagem 2 %32
    • Slide off the inner cover. It pulls apart and is held on by a small amount of glue.
    Pergunte ao FixBot
    Comentar
  6. VENSTAR Taco Speaker Replacement Replacement, Logic Board Replacement: passo 6, imagem 1 %32
    • Remove the rubber covering from the buttons.
    Pergunte ao FixBot
    Comentar
  7. VENSTAR Taco Speaker Replacement Replacement: passo 7, imagem 1 %32 VENSTAR Taco Speaker Replacement Replacement: passo 7, imagem 2 %32 VENSTAR Taco Speaker Replacement Replacement: passo 7, imagem 3 %32
    • Remove the black fabric covering the logic board.
    Pergunte ao FixBot
    Comentar
  8. VENSTAR Taco Speaker Replacement Replacement: passo 8, imagem 1 %32 VENSTAR Taco Speaker Replacement Replacement: passo 8, imagem 2 %32
    • Move the battery out of the way of the connector.
    Pergunte ao FixBot
    Comentar
  9. VENSTAR Taco Speaker Replacement Replacement: passo 9, imagem 1 %32 VENSTAR Taco Speaker Replacement Replacement: passo 9, imagem 2 %32
    • Undo the connector of the flat white ribbon between the switches and the logic board.
    Pergunte ao FixBot
    Comentar
  10. VENSTAR Taco Speaker Replacement Replacement: passo 10, imagem 1 %32
    • Undo the two black 3mm screws on the logic board using the PH0 screwdriver.
    Pergunte ao FixBot
    Comentar
  11. VENSTAR Taco Speaker Replacement Replacement: passo 11, imagem 1 %32 VENSTAR Taco Speaker Replacement Replacement: passo 11, imagem 2 %32 VENSTAR Taco Speaker Replacement Replacement: passo 11, imagem 3 %32
    • Gently pull out the logic board.
    • Note that the battery and the logic board are connected and must be removed together.
    Pergunte ao FixBot
    Comentar
  12. VENSTAR Taco Speaker Replacement Replacement, Speaker Replacement: passo 12, imagem 1 %32 VENSTAR Taco Speaker Replacement Replacement, Speaker Replacement: passo 12, imagem 2 %32
    • Using the Ph1 screwdriver, unscrew both of the 2.5mm screws on either side of the speakers.
    • The screws are glued in and may require the curved tweezers to pull all the way out.
    Pergunte ao FixBot
    Comentar
  13. VENSTAR Taco Speaker Replacement Replacement: passo 13, imagem 1 %32
    • Using a metal spudger, carefully wedge out the speakers from the casing.
    • Repeat this step for the removal of the other speaker.
    • Speakers are glued into the casing beyond being screwed and require some care to remove.
    Pergunte ao FixBot
    Comentar
  14. VENSTAR Taco Speaker Replacement Replacement: passo 14, imagem 1 %32
    • Using a portable soldering iron, melt the solder on the black speaker wires on the logic board.
    • Soldering uses hot metal and can burn you!
    Pergunte ao FixBot
    Comentar
Conclusão
Solder your replacement speakers back to mother board, then to reassemble your device, follow these instructions in reverse order.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 28
Ao todo: 645
