Ir para o conteúdo principal
VENSTAR Taco Microphone Replacement Replacement
O que você precisa
  1. VENSTAR Taco Microphone Replacement Replacement, VENSTAR Taco Disassembly: passo 1, imagem 1 %32 VENSTAR Taco Microphone Replacement Replacement, VENSTAR Taco Disassembly: passo 1, imagem 2 %32 VENSTAR Taco Microphone Replacement Replacement, VENSTAR Taco Disassembly: passo 1, imagem 3 %32
    • Starting with the Taco on its side, use the plastic opening tool to pop off the outer casing near the base.
    • The base labeled "VENSTAR TACO" is glued. Be careful separating the two sides of the device.
    Pergunte ao FixBot
    Comentar
  2. VENSTAR Taco Microphone Replacement Replacement: passo 2, imagem 1 %32 VENSTAR Taco Microphone Replacement Replacement: passo 2, imagem 2 %32
    • Repeat the previous step on the opposite side to remove the other outer casing.
    Pergunte ao FixBot
    Comentar
  3. VENSTAR Taco Microphone Replacement Replacement: passo 3, imagem 1 %32 VENSTAR Taco Microphone Replacement Replacement: passo 3, imagem 2 %32
    Ferramenta utilizada neste passo:
    Phillips #0 Screwdriver
    $5.49
    • Using a Phillips PH0 3 mm-bit screwdriver, remove the six screws on the inner layer of the Taco.
    • The screws are small and can get stuck. Use tweezers to pull them out if you are having trouble.
    Pergunte ao FixBot
    Comentar
  4. VENSTAR Taco Microphone Replacement Replacement: passo 4, imagem 1 %32 VENSTAR Taco Microphone Replacement Replacement: passo 4, imagem 2 %32
    • From the same side you just unscrewed, use a plastic opening tool to unwedge the inner cover on both sides of the base.
    Pergunte ao FixBot
    Comentar
  5. VENSTAR Taco Microphone Replacement Replacement: passo 5, imagem 1 %32 VENSTAR Taco Microphone Replacement Replacement: passo 5, imagem 2 %32
    • Slide off the inner cover. It pulls apart and is held on by a small amount of glue.
    Pergunte ao FixBot
    Comentar
  6. VENSTAR Taco Microphone Replacement Replacement, Logic Board Replacement: passo 6, imagem 1 %32
    • Remove the rubber covering from the buttons.
    Pergunte ao FixBot
    Comentar
  7. VENSTAR Taco Microphone Replacement Replacement: passo 7, imagem 1 %32 VENSTAR Taco Microphone Replacement Replacement: passo 7, imagem 2 %32 VENSTAR Taco Microphone Replacement Replacement: passo 7, imagem 3 %32
    • Remove the black fabric covering the logic board.
    Pergunte ao FixBot
    Comentar
  8. VENSTAR Taco Microphone Replacement Replacement: passo 8, imagem 1 %32 VENSTAR Taco Microphone Replacement Replacement: passo 8, imagem 2 %32
    • Move the battery out of the way of the connector.
    Pergunte ao FixBot
    Comentar
  9. VENSTAR Taco Microphone Replacement Replacement: passo 9, imagem 1 %32 VENSTAR Taco Microphone Replacement Replacement: passo 9, imagem 2 %32
    • Undo the connector of the flat white ribbon between the switches and the logic board.
    Pergunte ao FixBot
    Comentar
  10. VENSTAR Taco Microphone Replacement Replacement: passo 10, imagem 1 %32
    • Undo the two black 3mm screws on the logic board using the PH0 screwdriver.
    Pergunte ao FixBot
    Comentar
  11. VENSTAR Taco Microphone Replacement Replacement: passo 11, imagem 1 %32 VENSTAR Taco Microphone Replacement Replacement: passo 11, imagem 2 %32 VENSTAR Taco Microphone Replacement Replacement: passo 11, imagem 3 %32
    • Gently pull out the logic board.
    • Note that the battery and the logic board are connected and must be removed together.
    Pergunte ao FixBot
    Comentar
  12. VENSTAR Taco Microphone Replacement Replacement, Microphone Replacement: passo 12, imagem 1 %32 VENSTAR Taco Microphone Replacement Replacement, Microphone Replacement: passo 12, imagem 2 %32
    • Below the logic board, the small black microphone is resting within the case.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 41
Ao todo: 459
