Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Grasp the left ear cup cushion with your fingers and gently pull towards the center of the earcup. This will release the cushion from the tabs that are holding it in place.
Gently pull the ear cup from the rest of the tabs that hold it in place.
Remove the ear cup cushion.
Remove the six 10.1 mm Phillips screws securing the left headphone's speaker plate.
Insert an opening pick in the seam between the left headphone's plastic housing and metal rim.
Slide the pick along the seam and twist gently to loosen the speaker plate.
Grasp the metal rim with your fingers and gently pull it away from the headphone cup.
The battery is a Kanyo 350 mAh pack measuring 34mm x 24mm x 5mm.
The battery area can fit a battery that's up to 39.4mm x 31mm x 5mm.
Remove the two 5.9 mm Phillips screws securing the micro-USB port.
Use the flat end of a spudger to pry up and loosen the board from the two screw posts.
Carefully flip the board over and note the two solder joints connected to the battery cables.
De-solder the two solder joints and replace the battery. You will have to re-solder the battery to these contact points.
The back of the board is shown for reference.
9 outras pessoas executaram este guia.
14 comentários
any link to get the right battery Mr. Arthur?
I have not tried it, but a li-po pack like this should work, while even giving you a battery capacity boost. Again, you would need to solder the battery contacts on.
Hey just finished completing my battery replacement with flying colors thx for the guide and link to the replacement battery my man.
I’m glad to hear it worked out for you!
