Ir para o conteúdo principal
Using the 3DS's Safe Mode
  1. Using the 3DS's Safe Mode, Booting safe mode: passo 1, imagem 1 %32
    • Ensure the console is powered off
    • Hold the (L) + (R) + (A) + (D-Pad Up) buttons
    • Keep these buttons held down until the console boots in the next step
    • While still holding the other buttons, press the power button
    Pergunte ao FixBot
    Comentar
  2. Using the 3DS's Safe Mode, Updating the System: passo 2, imagem 1 %32 Using the 3DS's Safe Mode, Updating the System: passo 2, imagem 2 %32 Using the 3DS's Safe Mode, Updating the System: passo 2, imagem 3 %32
    • You should boot into a "system update" screen. Click OK and accept the prompts
    • If there's no working internet connection configured on your 3ds, you'll have the option to set one up now
    Pergunte ao FixBot
    Comentar
  3. Using the 3DS's Safe Mode: passo 3, imagem 1 %32
    • When the update finishes, the console will automatically turn off
    Pergunte ao FixBot
    Comentar
Conclusão
If your issue persists after following this guide, a system format may fix it. Or, if you'd prefer to keep your data, you can ask a question
3 outras pessoas executaram este guia.
darth mango
Membro desde: 03/13/23
3.754 Reputação
Autoria de 3 guias
4Comentários do guia
Does this work on old family 3ds?
maxxy waxxy - Responder Compartilhar
Works on every 3ds and 2ds model
darth mango - Responder Compartilhar
Hello Darth mango. I have had my 3ds xl (red btw) since 2016. It stopped working in 19 and I gave up. Never knew why, but when I tried this it didn't work. I see u have a reputation for fixing this stuff and I followed EVERY one of our guides. Nothing works. Should I just just go get it repaired, because NOTHING will work, even this.
Jahasen :D - Responder Compartilhar
Can you post a question about this? I try to avoid troubleshooting in comments as opposed to the forum made for it. Remember to include any symptoms (what happens when you plug it in, try to turn it on, etc.) as well as what fixes you've already tried. The better the info you give us, the better we'll be able to help. :D
Comentar
Visualizações:
Últimas 24 horas: 13
Últimos 7 dias: 100
Últimos 30 dias: 464
Ao todo: 15,800
