Ir para o conteúdo principal
Using a Floor Jack
O que você precisa
  1. Using a Floor Jack, Using a Floor Jack: passo 1, imagem 1 %32 Using a Floor Jack, Using a Floor Jack: passo 1, imagem 2 %32
    • Place the hydraulic floor jack under the vehicle until the saddle is directly under the crossmember.
    • The crossmember is the long metal support beam that runs underneath from the front fender to the rear fender on both sides of the car.
    • The saddle is the round metal part of the jack that moves upward as you pump the jack up.
    Pergunte ao FixBot
    Comentar
  2. Using a Floor Jack, Using floor jack to lift car.: passo 2, imagem 1 %32
    • Push downward on the jack's lever to lift the saddle upward so that it contacts the crossmember. Continue pushing downward on the lever to lift the car upward.
    Pergunte ao FixBot
    Comentar
  3. Using a Floor Jack: passo 3, imagem 1 %32
    • Place the jack stand under the jack mounting point.
    • The jack mounting point is a metallic protrusion beneath each of the car doors.
    Pergunte ao FixBot
    Comentar
  4. Using a Floor Jack: passo 4, imagem 1 %32
    • Raise the jack stand until it contacts the jack mounting point.
    • In the event the floor jack fails, the jack stand is designed to prevent the car from falling.
    Pergunte ao FixBot
    Comentar
Conclusão
8 outras pessoas executaram este guia.
Shaun MacDonald
Membro desde: 10/03/12
2.654 Reputação
Autoria de 8 guias
Equipe
Cal Poly, Team 24-27, Regan Fall 2012 Membro de Cal Poly, Team 24-27, Regan Fall 2012
CPSU-REGAN-F12S24G27
4 Membros
Autoria de 24 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 36
Últimos 30 dias: 229
Ao todo: 43,999
