Introdução
In this guide, we will update macOS, and run all Post-Installation patches to make your Mac feel normal once again. (We will not cover all potential work-arounds if an issue occurs)
O que você precisa
Okay, the big moment. It is time to update macOS using OpenCore.
First, we need to create a bootable USB drive for macOS.
Fortunately, there is a guide that covers how to do this:
Once you have created the Bootable USB Drive, made a backup of everything, and have successfully installed OpenCore on your Mac, you are ready to continue.
Restart your Mac, and hold down the Option (alt) key on your Mac.
In Startup Manager, you will see the OpenCore logo, and it will say "EFI Boot"
Ah, at last. The OpenCore OCLP Boot Menu. As you may notice, this Menu looks very similar to Startup Manager.
In this menu, you will see your Internal Drive (Probably Macintosh HD) and your USB drive you just created. That's where we want to boot. Choose the USB drive, and click the arrow to boot.
One last step, we need to install any patches for your Mac.
Open up the OpenCore-Patcher app (Probably still in your Applications folder if you installed OpenCore with the package and upgraded macOS), and you will see a button available: Post-Install Root Patch.
Click that button, and OpenCore will search for aplicable root patches (Graphics Driver, Bluetooth, USB, etc.)
Once all patches are found, click on "Start Root Patching"
When OpenCore relaunches, you will see a bunch of text scroll through rapidly.
Eventually, a new window will apear asking to reboot. Click the "Reboot" button, and then "Restart" in the power menu. After your Mac reboots, all patches will have been applied, and your Mac will be ready to roll.
Please note your Mac is probably not completely ready. You will still have to make sure OpenCore is installed on your Mac's internal Hard Drive.
To make booting a bit more snappy, open the OpenCore app once more, and uncheck "Show OpenCore Boot Picker" That way, your Mac will immediately boot without showing the OCLP menu at every startup.
All done! macOS is updated and you are ready to use your Mac. If you start to notice issues later on, check out Guide #5.
9 outras pessoas executaram este guia.
4Comentários do guia
Donde esta la guia #5? / Where´s the guide #5?
Lo siento por la demora. Había fallas técnicas aquí probando las computadoras. En unas semanas no más ya estará lista.
Guide #5 is now available!
I have Ventura 13.7.8 installed. Tried to install Sonoma as instructed, all great until I try to select drive which is greyed out and says "cannot downgrade max OS version" or something like that. Is the Sonoma download from apple older than Ventura? Or something else?
