Ir para o conteúdo principal
Uniden UTAB71 Speaker Replacement
O que você precisa
  1. Uniden UTAB71 Speaker Replacement, Speaker: passo 1, imagem 1 %32 Uniden UTAB71 Speaker Replacement, Speaker: passo 1, imagem 2 %32
    • Use a plastic pry tool to undo the clips that attach the two halves of the tablet.
    • Make sure to be gentle with the pry tool and work your way around the edges of the tablet slowly.
    • Make sure the tablet is powered off before prying open.
    • There are two power ribbons connecting the screen to the back of the tablet. Make sure not to put too much stress on them.
  2. Uniden UTAB71 Speaker Replacement: passo 2, imagem 1 %32
    • Use a soldering tool to disconnect the speaker wires off the motherboard.
    • If you have no experience in soldering, please follow this guide
Conclusão
Ryan Jewell
Membro desde: 10/20/16
422 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team 5-4, Martin Fall 2016 Membro de UMass Dartmouth, Team 5-4, Martin Fall 2016
UMASSD-MARTIN-F16S5G4
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 159
