Ir para o conteúdo principal
Uniden UTAB71 Battery Replacement
O que você precisa
  1. Uniden UTAB71 Battery Replacement, Battery: passo 1, imagem 1 %32 Uniden UTAB71 Battery Replacement, Battery: passo 1, imagem 2 %32
    • Use a plastic opening tool to undo the clips that attach the two halves of the tablet.
    • Be gentle with the pry tool and work your way around the edges of the tablet slowly.
    • Make sure the tablet is powered off before prying open.
    • There are two power ribbons connecting the screen to the back of the tablet. Make sure not to put too much stress on them.
  2. Uniden UTAB71 Battery Replacement: passo 2, imagem 1 %32
    • Lift off the tape that holds the speaker wires to the battery
    • Leave the tape off to the side
  3. Uniden UTAB71 Battery Replacement: passo 3, imagem 1 %32
    • Use a soldering tool to disconnect the two wires (red and black) that connect the battery to the motherboard
    • Note the placement of each colored wire in the motherboard
    • If you have no experience in soldering, please follow this guide
  4. Uniden UTAB71 Battery Replacement: passo 4, imagem 1 %32 Uniden UTAB71 Battery Replacement: passo 4, imagem 2 %32
    Ferramenta utilizada nesse passo:
    iOpener
    $12.99
    Comprar
    • Use a credit card to lift the battery off the back of the tablet
    • Do not put any pressure on the motherboard or any other internal components.
    • The battery attached to the back panel with adhesive. You may need to use a heated iOpener to loosen the adhesive and remove the battery.
Conclusão
Ryan Jewell
Membro desde: 10/20/16
422 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team 5-4, Martin Fall 2016 Membro de UMass Dartmouth, Team 5-4, Martin Fall 2016
UMASSD-MARTIN-F16S5G4
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 344
