Ir para o conteúdo principal
Uniden Dect 6.0 Display Replacement
O que você precisa
  1. Uniden Dect 6.0 Display Replacement, Battery: passo 1, imagem 1 %32
    • Locate the battery compartment on the back of the Uniden home phone.
    • Place your finger on the groove, and pull directly back on the cover to access to the battery.
  2. Uniden Dect 6.0 Display Replacement: passo 2, imagem 1 %32
    • Remove the white battery pack from the battery compartment.
  3. Uniden Dect 6.0 Display Replacement: passo 3, imagem 1 %32
    • Remove the red-and-black-wired port from the plug directly under the battery compartment.
  4. Uniden Dect 6.0 Display Replacement, Keyboard: passo 4, imagem 1 %32 Uniden Dect 6.0 Display Replacement, Keyboard: passo 4, imagem 2 %32
    • Using a Phillips #1 screwdriver, remove the two .9 mm screws on the back of the device on each side of the battery pack.
  5. Uniden Dect 6.0 Display Replacement: passo 5, imagem 1 %32
    • Using your fingers, gently lift and separate the front of the housing from the back housing.
    • Potential for device damage: While separating the back housing from the front, be sure to open from the sides as pictured.
  6. Uniden Dect 6.0 Display Replacement: passo 6, imagem 1 %32
    • Gently remove the loose keyboard from the lined gel casing located under the front housing of the front of the phone.
  7. Uniden Dect 6.0 Display Replacement, Gel Casing: passo 7, imagem 1 %32
    • To better access the screen, remove the loose gel casing that sits under the keyboard.
  8. Uniden Dect 6.0 Display Replacement: passo 8, imagem 1 %32
    • Lift out the attached motherboard piece and turn it sideways to access the side of the phone.
    • Potential for device damage: Use caution to avoid severing the wires that connect the motherboard to the phone.
  9. Uniden Dect 6.0 Display Replacement: passo 9, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Gently use the tweezers to access the motherboard panel and lift it straight up.
Conclusão
3 outras pessoas executaram este guia.
Megan Lawrence
Membro desde: 01/14/15
534 Reputação
Autoria de 5 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 39
Duração total: 6,382
