Ir para o conteúdo principal
UTStarcom XV6700 Camera Replacement
O que você precisa
  1. UTStarcom XV6700 Camera Replacement, Battery: passo 1, imagem 1 %32
    • Press the on/off button on the top to power the phone off.
    Pergunte ao FixBot
    Comentar
  2. UTStarcom XV6700 Camera Replacement: passo 2, imagem 1 %32
    • Remove the battery cover by pressing and sliding the cover down and off of the phone.
    Pergunte ao FixBot
    Comentar
  3. UTStarcom XV6700 Camera Replacement: passo 3, imagem 1 %32 UTStarcom XV6700 Camera Replacement: passo 3, imagem 2 %32 UTStarcom XV6700 Camera Replacement: passo 3, imagem 3 %32
    • Pull the battery removal tab and lift the battery out of the phone.
    • If the battery removal tab is missing, place a spudger on the opposite side of the highlighted connector and pry the battery up.
    Pergunte ao FixBot
    Comentar
  4. UTStarcom XV6700 Camera Replacement, Camera: passo 4, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Remove the two 4.0-mm #000 Phillips screws at the top of the battery compartment. Tweezers may be useful to remove the screws.
    Pergunte ao FixBot
    Comentar
  5. UTStarcom XV6700 Camera Replacement: passo 5, imagem 1 %32 UTStarcom XV6700 Camera Replacement: passo 5, imagem 2 %32
    • Use firm pressure to carefully pry off the cover with your fingers.
    Pergunte ao FixBot
    Comentar
  6. UTStarcom XV6700 Camera Replacement: passo 6, imagem 1 %32
    • Remove the 4.0-mm #00 Phillips screw securing the camera flash circuit board. The board is still connected by a connector on the bottom of the board.
    Pergunte ao FixBot
    Comentar
  7. UTStarcom XV6700 Camera Replacement: passo 7, imagem 1 %32
    • Gently pry off the camera flash circuit board with the spudger.
    Pergunte ao FixBot
    Comentar
  8. UTStarcom XV6700 Camera Replacement: passo 8, imagem 1 %32
    • Gently pry off the camera with the spudger.
    Pergunte ao FixBot
    Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 24
Ao todo: 484
