Ir para o conteúdo principal
UTStarcom XV6700 Battery Replacement
O que você precisa
  1. UTStarcom XV6700 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Press the on/off button on the top to power the phone off.
    Pergunte ao FixBot
    Comentar
  2. UTStarcom XV6700 Battery Replacement: passo 2, imagem 1 %32
    • Remove the battery cover by pressing and sliding the cover down and off of the phone.
    Pergunte ao FixBot
    Comentar
  3. UTStarcom XV6700 Battery Replacement: passo 3, imagem 1 %32 UTStarcom XV6700 Battery Replacement: passo 3, imagem 2 %32 UTStarcom XV6700 Battery Replacement: passo 3, imagem 3 %32
    • Pull the battery removal tab and lift the battery out of the phone.
    • If the battery removal tab is missing, place a spudger on the opposite side of the highlighted connector and pry the battery up.
    Pergunte ao FixBot
    Comentar
Conclusão
1Comentário do guia
it wont keep a charge, ive bought new battery and it will turn on load up. at main screen no longer than 10 seconds and shuts off.
jloizos79 - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 41
Ao todo: 783
