Ir para o conteúdo principal
UTStarcom CDM8945vw Speaker Replacement
O que você precisa
  1. UTStarcom CDM8945vw Speaker Replacement, Battery: passo 1, imagem 1 %32
    • Push the highlighted button in the direction in which the antenna is pointing. The battery will release and pop up.
    Pergunte ao FixBot
    Comentar
  2. UTStarcom CDM8945vw Speaker Replacement: passo 2, imagem 1 %32
    • Remove the battery.
    Pergunte ao FixBot
    Comentar
  3. UTStarcom CDM8945vw Speaker Replacement, Antenna: passo 3, imagem 1 %32
    • Identify the antenna. It is the extendable plastic component pictured here.
    Pergunte ao FixBot
    Comentar
  4. UTStarcom CDM8945vw Speaker Replacement: passo 4, imagem 1 %32
    • Twist the base in a counter-clockwise motion to unscrew the antenna.
    Pergunte ao FixBot
    Comentar
  5. UTStarcom CDM8945vw Speaker Replacement: passo 5, imagem 1 %32 UTStarcom CDM8945vw Speaker Replacement: passo 5, imagem 2 %32
    • The antenna should slide right out of the phone when finished.
    Pergunte ao FixBot
    Comentar
  6. UTStarcom CDM8945vw Speaker Replacement, Speaker: passo 6, imagem 1 %32
    • Remove the small rubber grommet using the plastic opening tool.
    Pergunte ao FixBot
    Comentar
  7. UTStarcom CDM8945vw Speaker Replacement: passo 7, imagem 1 %32
    • Remove five screws using a Phillips #00 screwdriver.
    Pergunte ao FixBot
    Comentar
  8. UTStarcom CDM8945vw Speaker Replacement: passo 8, imagem 1 %32
    • Use the plastic opening tool to separate the two pieces that form the outer case of the phone.
    • Prying the two pieces apart may be difficult. Carefully apply a moderate amount of pressure when attempting to separate the two pieces or else you will risk breaking them.
    Pergunte ao FixBot
    Comentar
  9. UTStarcom CDM8945vw Speaker Replacement: passo 9, imagem 1 %32
    • Remove the back piece of the outer case.
    Pergunte ao FixBot
    Comentar
  10. UTStarcom CDM8945vw Speaker Replacement: passo 10, imagem 1 %32
    • Remove the speaker using a plastic opening tool.
    • Apply a small amount of force when removing the broken speaker from the motherboard. If you apply a large amount of force, you may rip out the wires and damage the motherboard.
    Pergunte ao FixBot
    Comentar
  11. UTStarcom CDM8945vw Speaker Replacement: passo 11, imagem 1 %32 UTStarcom CDM8945vw Speaker Replacement: passo 11, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Remove the wire attached to the speaker from the motherboard using tweezers.
    • Apply a small amount of force when removing the wire from the motherboard. If you apply a large amount of force, you may rip out the wires and damage the motherboard.
    Pergunte ao FixBot
    Comentar
Conclusão
Eli
Membro desde: 09/27/12
1 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 24-26, Regan Fall 2012 Membro de Cal Poly, Team 24-26, Regan Fall 2012
CPSU-REGAN-F12S24G26
4 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 24
Ao todo: 592
