Ir para o conteúdo principal
USB Power for Remington MB4040
O que você precisa
  1. USB Power for Remington MB4040, Remove Blade Assembly: passo 1, imagem 1 %32 USB Power for Remington MB4040, Remove Blade Assembly: passo 1, imagem 2 %32 USB Power for Remington MB4040, Remove Blade Assembly: passo 1, imagem 3 %32
    • Press the black button below the blade to remove the blade.
  2. USB Power for Remington MB4040, Remove Back Cover Hardware: passo 2, imagem 1 %32 USB Power for Remington MB4040, Remove Back Cover Hardware: passo 2, imagem 2 %32
    • Place the device so the back of the product is facing up.
    • Remove the two 11.0 mm PH00 screws from the black plastic housing at the bottom of the device.
  3. USB Power for Remington MB4040, Remove Front Cover Hardware: passo 3, imagem 1 %32 USB Power for Remington MB4040, Remove Front Cover Hardware: passo 3, imagem 2 %32 USB Power for Remington MB4040, Remove Front Cover Hardware: passo 3, imagem 3 %32
    • Remove the chrome plated plastic piece by using the plastic opening tool to pry it from the housing assembly.
    • Remove the small clear plastic piece that covers the zoom wheel numbers.
  4. USB Power for Remington MB4040, Front Cover (cont.): passo 4, imagem 1 %32 USB Power for Remington MB4040, Front Cover (cont.): passo 4, imagem 2 %32
    • Remove the two 16.0 mm PH00 screws from the front cover.
    • Use the blue plastic opening tool to pry apart the two halves of the device.
  5. USB Power for Remington MB4040, Blade Button Removal: passo 5, imagem 1 %32 USB Power for Remington MB4040, Blade Button Removal: passo 5, imagem 2 %32
    • Remove the black blade button and the two 10.0 mm springs, which are sandwiched between the cover assembly halves.
    • The blade button is sandwiched between the halves and the two springs may fall out when the halves are separated.
  6. USB Power for Remington MB4040, Remove Motherboard: passo 6, imagem 1 %32 USB Power for Remington MB4040, Remove Motherboard: passo 6, imagem 2 %32
    • Remove the four 9.0 mm PH00 screws from the motherboard.
    • Use the plastic opening tool to remove the motherboard from its housing.
    • This can be completed with the Remington MB4040 Zoom Wheel Replacement installed or removed. Just adjust the zoom wheel until it no longer covers the motherboard.
  7. USB Power for Remington MB4040, Remove Battery: passo 7, imagem 1 %32 USB Power for Remington MB4040, Remove Battery: passo 7, imagem 2 %32 USB Power for Remington MB4040, Remove Battery: passo 7, imagem 3 %32
    • Remove the thermal switch from the battery by using the spudger to pry it from the adhesive.
    • Remove the battery by desoldering the battery from the motherboard.
    • Soldering tabs hold the battery onto the motherboard.
  8. USB Power for Remington MB4040, Remove Battery, Cap, Sensor: passo 8, imagem 1 %32
    • Remove the battery sensor (glued to battery), battery, capacitor.
    • Cut motor leads at the PCB (marked M+ and M-).
    • Strip the freshly-cut ends of the motor wires so they can be reconnected in a later step.
  9. USB Power for Remington MB4040, Remove Unnecessary Diodes: passo 9, imagem 1 %32
    • Remove all diodes marked in Red.
    • Leave diode marked D1 on PCB.
  10. USB Power for Remington MB4040, Add power extension wires to PCB: passo 10, imagem 1 %32
    • The wires for the motor will need to be extended. See next steps to help plan extension lengths.
    • Solder extension wires to PCB.
  11. USB Power for Remington MB4040: passo 11, imagem 1 %32
    • Solder extension wires to motor wires.
    • Use heat-shrink tubing or electrical tape.
  12. USB Power for Remington MB4040, Prepare components for assembly: passo 12, imagem 1 %32
    • Install PCB with four screws.
    • Route wiring as shown.
    • Move zoom dial to check clearance with wires.
    • Move switch shown in yellow to match cover switch.
  13. USB Power for Remington MB4040, Cut Cables, Connect, and Test Voltage: passo 13, imagem 1 %32 USB Power for Remington MB4040, Cut Cables, Connect, and Test Voltage: passo 13, imagem 2 %32
    • First of all, I apologize that there are not more detailed photos for this section. I decided to put this guide together after I had completed it. I'll do my best to explain, but please let me know if I can clarify.
    • Cut off old power adapter and keep the cable (with the shaver connector). This is black in the photo.
    • Cut off non-USB-A end of a USB-A cable and keep the USB-A end. This cable is white in the photo.
    • On the cut end of USB cable, strip wires. Ensure they don't touch during next step.
    • Plug power adapter to wall, then connect USB cable. Measure DC voltage between each wire and ground of connector (bare metal portion at adapter end). Note the 5V output and 0V output wires. There should be only one of each. (The other two wires are for communications. https://www.electroschematics.com/usb-ho...)
    • Unplug the power adapter. Cut off the exposed portions of the other wires. Those need to be soldered to the old power cable. Unplug the adapter. Note the 5V output and 0V output and cut off the exposed portions of the other wires. The 5V and 0V wires need to be soldered to the old power cable.
    • Strip the ends of the old power cable. Connect to the USB wires (area outlined in red in photo). Connect power adapter to wall and measure final output. The center tap of the old power connector should be 5V relative to 0V of the barrel of the connector. If it is -5V, you will need to reverse the connection.
    • Insulate each connection using shrink wrap tubing before soldering. Solder. Position and heat shrink wrap. (If not shrink wrapping, wrap both wires with electrical tape.)
  14. USB Power for Remington MB4040, Quick Test: passo 14, imagem 1 %32
    • Before reassembling the shaver, connect it to power using the new cable. It should sound like it normally does after a fresh charge.
    • Disconnect from power after testing (Remember the power button will not function anymore.)
  15. USB Power for Remington MB4040, Start Reassembling: passo 15, imagem 1 %32 USB Power for Remington MB4040, Start Reassembling: passo 15, imagem 2 %32
    • Insert the button assembly shown in a yellow oval. (This is used to release the stainless blade assembly.)
    • Insert the springs show in yellow rectangles.
    • Hold the button assembly while flipping the left casing over the right casing.
  16. USB Power for Remington MB4040, Align Casings and Springs: passo 16, imagem 1 %32
    • BEFORE snapping casings together, ensure springs are secured by upper casing alignment pins (inside springs).
    • Snap cases together starting at the end with the power connector.
  17. USB Power for Remington MB4040, Finishing Up: passo 17, imagem 1 %32
    • Return to pre-requisite guide to review disassembly process.
    • As reassembly suggestions, BEFORE snapping chrome piece in place:
    • 1) Remember to install transparent zoom-button lens and smoky-transparent power-button-shroud into chrome piece.
    • 2) When snapping chrome piece in place, start at end with power adapter.
    • Final work should look something like the photo. Happy shaving!
Conclusão
To reassemble your device, follow these prerequisite instructions in reverse. It’s a fussy process, but not as hard as taking it apart.
Make A. Mend
Membro desde: 11/11/20
181 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 10
Duração total: 585
