Ir para o conteúdo principal
UP! Plus 2 Nozzle Replacement
O que você precisa
    1. UP! Plus 2 Nozzle Replacement, Turn on your printer: passo 1, imagem 1 %32
      • Plug in the AC Power adapter and USB cable into the back of the printer.
      • Connect your printer to the computer via USB.
      • Turn on the printer and initialize it.
      Pergunte ao FixBot
      Comentar
    2. UP! Plus 2 Nozzle Replacement, Verify the nozzle temperature: passo 2, imagem 1 %32
      • Open the UP! software on your computer, and bring up the "maintenance window."
      • Under maintenance, click "extrude."
      • Then, verify if the nozzle temperature is rising by looking at the status box in the same maintenance window.
      Pergunte ao FixBot
      Comentar
    3. UP! Plus 2 Nozzle Replacement, Remove nozzle: passo 3, imagem 1 %32 UP! Plus 2 Nozzle Replacement, Remove nozzle: passo 3, imagem 2 %32
      • The nozzle needs to be greater than 200 degrees Celsius before removal.
      • Before handling the nozzle please put on heat resistant gloves in order to prevent burns.
      • Using the 6mm hex wrench, apply force by pushing up to lock the nozzle into the wrench and turn counterclockwise to loosen the nozzle.
      Pergunte ao FixBot
      Comentar
    4. UP! Plus 2 Nozzle Replacement, Attach the new nozzle: passo 4, imagem 1 %32
      • Before attaching the new nozzle, make sure the temperature is still greater than 200 degrees Celsius.
      • Attach the new nozzle with the hex wrench by screwing it on in a clockwise manner.
      • If there is any extra plastic coming out of the extruder, cut it off before attaching the new nozzle.
      Pergunte ao FixBot
      Comentar
Conclusão
valerie boyer
Membro desde: 10/12/14
508 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 14-31, Maness Fall 2014 Membro de Cal Poly, Team 14-31, Maness Fall 2014
CPSU-MANESS-F14S14G31
4 Membros
Autoria de 30 guias
1Comentário do guia
I have a problem with my UP PLUS 3D printer and I really need your help. First printer started to stop in the middle of the printing, then got to the point where I wasn’t even able to connect it to my laptop (it didn’t recognize it) and now, when I press Print, before even slicing completes, the software crashes and I have to reopen (basically I can’t print anything as every time I try, same thing happens). The weird part is that sometimes I can adjust the bed, heat up extruder, extract or retract filament from software but the moment I press print, it dies. PLEASE HELP!!!
Nima - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 8
Últimos 30 dias: 36
Ao todo: 3,204
