Introdução
This guide demonstrates how to remove and replace the front buttons of your Turtle Beach Recon.
The front buttons are responsible for the majority of the input from your Turtle Beach Recon. The front buttons include functions of movement, menu, and power.
It is often necessary to remove and replace the front buttons should they be faulty, visibly broken, or dirty.
O que você precisa
Use a Phillips #00 screwdriver to remove seven 10 mm screws from the back plate.
Remove the four 10 mm screws from the motherboard using a Phillips #00 screwdriver.
