Ir para o conteúdo principal
Turtle Beach Recon Controller Front Buttons Replacement
O que você precisa
  1. Turtle Beach Recon Controller Front Buttons Replacement, Back Plate: passo 1, imagem 1 %32 Turtle Beach Recon Controller Front Buttons Replacement, Back Plate: passo 1, imagem 2 %32 Turtle Beach Recon Controller Front Buttons Replacement, Back Plate: passo 1, imagem 3 %32
    • Use a Phillips #00 screwdriver to remove seven 10 mm screws from the back plate.
    • When replacing the screws, ensure that the screwdriver is perpendicular to the screw in curved areas.
    Pergunte ao FixBot
    Comentar
  2. Turtle Beach Recon Controller Front Buttons Replacement: passo 2, imagem 1 %32 Turtle Beach Recon Controller Front Buttons Replacement: passo 2, imagem 2 %32 Turtle Beach Recon Controller Front Buttons Replacement: passo 2, imagem 3 %32
    • Use an opening tool to separate the back plate from the grips of your Turtle Beach Recon.
    • Use your fingers to remove the back plate from the body of your Turtle Beach Recon.
    Pergunte ao FixBot
    Comentar
  3. Turtle Beach Recon Controller Front Buttons Replacement, Face Plate: passo 3, imagem 1 %32 Turtle Beach Recon Controller Front Buttons Replacement, Face Plate: passo 3, imagem 2 %32
    • Remove the four 10 mm screws from the motherboard using a Phillips #00 screwdriver.
    Pergunte ao FixBot
    Comentar
  4. Turtle Beach Recon Controller Front Buttons Replacement: passo 4, imagem 1 %32 Turtle Beach Recon Controller Front Buttons Replacement: passo 4, imagem 2 %32
    • Use your fingers to grab the motherboard.
    • Gently pull the motherboard and joystick caps away from the face plate.
    Pergunte ao FixBot
    Comentar
  5. Turtle Beach Recon Controller Front Buttons Replacement: passo 5, imagem 1 %32 Turtle Beach Recon Controller Front Buttons Replacement: passo 5, imagem 2 %32 Turtle Beach Recon Controller Front Buttons Replacement: passo 5, imagem 3 %32
    • Use a Phillips #00 screwdriver to remove six 10 mm screws from the motherboard.
    Pergunte ao FixBot
    Comentar
  6. Turtle Beach Recon Controller Front Buttons Replacement, Front Buttons: passo 6, imagem 1 %32 Turtle Beach Recon Controller Front Buttons Replacement, Front Buttons: passo 6, imagem 2 %32 Turtle Beach Recon Controller Front Buttons Replacement, Front Buttons: passo 6, imagem 3 %32
    • Gently remove front buttons from the face plate by hand.
    Pergunte ao FixBot
    Comentar
Conclusão
Mary Goodrow
Membro desde: 03/22/24
716 Reputação
Autoria de 5 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 37
Ao todo: 726
