Introdução
If you find that your microphone has broken after extensive use or damage, you may want to take the opportunity to replace it before buying a new headset. This guide will take you through the steps necessary to ensure that your microphone replaced and working again.
O que você precisa
Use a spudger to pry up the black plastic housing.
Remove the plastic cover.
Quase terminado!
Conclusão
