Ir para o conteúdo principal
Turtle Beach REACT-R Bumpers Replacement
O que você precisa
  1. Turtle Beach REACT-R Bumpers Replacement, Rear Case: passo 1, imagem 1 %32 Turtle Beach REACT-R Bumpers Replacement, Rear Case: passo 1, imagem 2 %32 Turtle Beach REACT-R Bumpers Replacement, Rear Case: passo 1, imagem 3 %32
    • Place the controller face down.
    • Use a Phillips #00 screwdriver to remove the seven 9.2 mm Phillips screws that secure the rear case.
    • Use both hands to lift the backplate away from the controller.
    Pergunte ao FixBot
    Comentar
  2. Turtle Beach REACT-R Bumpers Replacement, Motherboard: passo 2, imagem 1 %32 Turtle Beach REACT-R Bumpers Replacement, Motherboard: passo 2, imagem 2 %32 Turtle Beach REACT-R Bumpers Replacement, Motherboard: passo 2, imagem 3 %32
    • Use a Phillips #00 to remove the four 9.2 mm screws that secure the motherboard.
    • Two of the screws are hidden under the red and black vibration motor wires.
    • Gently lift the motherboard up and out of the chassis.
    • Be careful not to strain the vibration motor wires.
    Pergunte ao FixBot
    Comentar
  3. Turtle Beach REACT-R Bumpers Replacement, Bumpers: passo 3, imagem 1 %32 Turtle Beach REACT-R Bumpers Replacement, Bumpers: passo 3, imagem 2 %32 Turtle Beach REACT-R Bumpers Replacement, Bumpers: passo 3, imagem 3 %32
    • Use a Phillips screwdriver to remove the two 9.2 mm screws that secure the right and left bumpers to the face plate.
    • Gently remove each bumper from the faceplate.
    Pergunte ao FixBot
    Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 42
Ao todo: 747
