Ir para o conteúdo principal
Turtle Beach Elite 800 Battery Replacement
O que você precisa
  1. Turtle Beach Elite 800 Battery Replacement, Ear Cushion: passo 1, imagem 1 %32 Turtle Beach Elite 800 Battery Replacement, Ear Cushion: passo 1, imagem 2 %32
    • To remove the ear cushions, press firmly down and rotate them clockwise, it should twist about 2mm and release, allowing you to pull it off.
    • When reassembling, be sure to line up the locking plates.
  2. Turtle Beach Elite 800 Battery Replacement, Audio Board: passo 2, imagem 1 %32 Turtle Beach Elite 800 Battery Replacement, Audio Board: passo 2, imagem 2 %32
    • Remove the screws (9.47 mm Phillips head) from the blue plating on the headset to reveal the inside.
  3. Turtle Beach Elite 800 Battery Replacement: passo 3, imagem 1 %32 Turtle Beach Elite 800 Battery Replacement: passo 3, imagem 2 %32
    • If you are working on the LEFT side ear, you will first have to detach the battery by gently unplugging the white plug on the top of the board.
    • Make sure when unplugging the battery to not pull the manilla colored part which is attached to the board, but the white plug instead.
    • If you are working on the RIGHT side ear, you will first have to remove the charging contacts (2 7.92 mm Phillips screws).
  4. Turtle Beach Elite 800 Battery Replacement: passo 4, imagem 1 %32 Turtle Beach Elite 800 Battery Replacement: passo 4, imagem 2 %32 Turtle Beach Elite 800 Battery Replacement: passo 4, imagem 3 %32
    • Desolder the necessary wires. (Each side will be slightly different.)
    • Be careful when using a soldering iron. Refer to the desoldering guide for tips.
    • For the purpose of this guide we clipped the wires connected to the board.
    • Remove the 4 screws (7.71mm Phillips head) using the #0 screw bit, that are holding the board in place.
    • Finally, remove the audio board.
  5. Turtle Beach Elite 800 Battery Replacement, Battery: passo 5, imagem 1 %32 Turtle Beach Elite 800 Battery Replacement, Battery: passo 5, imagem 2 %32 Turtle Beach Elite 800 Battery Replacement, Battery: passo 5, imagem 3 %32
    • Remove the battery by carefully prying it from the headset.
Conclusão
13 outras pessoas executaram este guia.
55 comentários
So there are two batteries in this headset that need to be replaced?
Doug Green - Responder
Also, what battery do I purchase and does anyone know a good source to purchase them?
Max battery size: 50x36x9mm
Origina battery: 40x30x8mm
The pcm board can be replacement by old battery module.
Dariusz Fukiet - Responder
Only one battery inside. Not sure why this guide takes appart the whole headset.
All steps&pictures related to right side (step 1, 2 and 4) are misleading and unnecessary when doing just battery replacement.
I ordered replacement on aliexpress.
joze_markic_bf - Responder
What part number please and thank you in advance
jon fystro -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 26
Duração total: 32,320
