Ir para o conteúdo principal
Turtle Beach Elite 800 Audio Board Replacement
O que você precisa
  1. Turtle Beach Elite 800 Audio Board Replacement, Ear Cushion: passo 1, imagem 1 %32 Turtle Beach Elite 800 Audio Board Replacement, Ear Cushion: passo 1, imagem 2 %32
    • To remove the ear cushions, press firmly down and rotate them clockwise, it should twist about 2mm and release, allowing you to pull it off.
    • When reassembling, be sure to line up the locking plates.
  2. Turtle Beach Elite 800 Audio Board Replacement, Audio Board: passo 2, imagem 1 %32 Turtle Beach Elite 800 Audio Board Replacement, Audio Board: passo 2, imagem 2 %32
    • Remove the screws (9.47 mm Phillips head) from the blue plating on the headset to reveal the inside.
  3. Turtle Beach Elite 800 Audio Board Replacement: passo 3, imagem 1 %32 Turtle Beach Elite 800 Audio Board Replacement: passo 3, imagem 2 %32
    • If you are working on the LEFT side ear, you will first have to detach the battery by gently unplugging the white plug on the top of the board.
    • Make sure when unplugging the battery to not pull the manilla colored part which is attached to the board, but the white plug instead.
    • If you are working on the RIGHT side ear, you will first have to remove the charging contacts (2 7.92 mm Phillips screws).
  4. Turtle Beach Elite 800 Audio Board Replacement: passo 4, imagem 1 %32 Turtle Beach Elite 800 Audio Board Replacement: passo 4, imagem 2 %32 Turtle Beach Elite 800 Audio Board Replacement: passo 4, imagem 3 %32
    • Desolder the necessary wires. (Each side will be slightly different.)
    • Be careful when using a soldering iron. Refer to the desoldering guide for tips.
    • For the purpose of this guide we clipped the wires connected to the board.
    • Remove the 4 screws (7.71mm Phillips head) using the #0 screw bit, that are holding the board in place.
    • Finally, remove the audio board.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 13
Duração total: 1,945
