Ir para o conteúdo principal
Turtle Beach Ear Force XO Four Speaker Cone Replacement
O que você precisa
  1. Turtle Beach Ear Force XO Four Speaker Cone Replacement, Ear Cushion: passo 1, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Jimmy
    $7.95
    Comprar
    • Insert a flat metal object (such as iFixit's Jimmy tool) between the green and black plastic portions of the headset.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
  2. Turtle Beach Ear Force XO Four Speaker Cone Replacement: passo 2, imagem 1 %32 Turtle Beach Ear Force XO Four Speaker Cone Replacement: passo 2, imagem 2 %32
    • Carefully pry the plastic pieces apart, working your way around the ear cushion.
    • Be sure not to break the tabs on the back side of the ear pad!
  3. Turtle Beach Ear Force XO Four Speaker Cone Replacement: passo 3, imagem 1 %32 Turtle Beach Ear Force XO Four Speaker Cone Replacement: passo 3, imagem 2 %32 Turtle Beach Ear Force XO Four Speaker Cone Replacement: passo 3, imagem 3 %32
    • Pull the loosened ear pad apart from the rest of the speaker.
    • Pushing the pad and the speaker back together is the only step required for ear pad reassembly.
  4. Turtle Beach Ear Force XO Four Speaker Cone Replacement, Speaker Cone: passo 4, imagem 1 %32 Turtle Beach Ear Force XO Four Speaker Cone Replacement, Speaker Cone: passo 4, imagem 2 %32
    • Remove four 7.3mm PH0 screws.
    • As these screws are very small, it may be best to keep them in a plastic bag or other container.
  5. Turtle Beach Ear Force XO Four Speaker Cone Replacement: passo 5, imagem 1 %32 Turtle Beach Ear Force XO Four Speaker Cone Replacement: passo 5, imagem 2 %32
    • Lift speaker cone off of the back casing.
    • Be gentle; the small wires connecting the speaker cone to the rest of the device may break if you pull too hard.
    • Follow iFixit's soldering guide to remove the wires connected to the speaker.
Conclusão
9 outras pessoas executaram este guia.
Evalyn Johnson
Membro desde: 09/22/15
228 Reputação
Autoria de 2 guias
Equipe
Baylor, Team 10-14, Williams Fall 2015 Membro de Baylor, Team 10-14, Williams Fall 2015
BU-WILLIAMS-F15S10G14
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 10
Duração total: 9,409
