Ir para o conteúdo principal
Turtle Beach Ear Force P11 Speakers Replacement
O que você precisa
  1. Turtle Beach Ear Force P11 Speakers Replacement, Ear Cushion: passo 1, imagem 1 %32
    • Pinch the inner edge of the ear cushion from the bottom.
  2. Turtle Beach Ear Force P11 Speakers Replacement: passo 2, imagem 1 %32
    • Now slowly pull down the ear cushion as it completely separates from the speaker.
    • Carry out the pulling down action as slowly as possible or you might risk tearing the ear cushion otherwise
  3. Turtle Beach Ear Force P11 Speakers Replacement, Speakers: passo 3, imagem 1 %32
    • Remove the 4 screws on the red speaker cover.
    • It is recommended to use a #000 Philips Screw Driver
  4. Turtle Beach Ear Force P11 Speakers Replacement: passo 4, imagem 1 %32 Turtle Beach Ear Force P11 Speakers Replacement: passo 4, imagem 2 %32
    • Inspect the wires for damage as illustrated
  5. Turtle Beach Ear Force P11 Speakers Replacement: passo 5, imagem 1 %32
    • De-solder the speaker wires and remove the speaker.
    • Use low heat for de - soldering
  6. Turtle Beach Ear Force P11 Speakers Replacement: passo 6, imagem 1 %32
    • Solder the new speaker wires in the same position as the old one.
    • It is advisable to use a lead free solder
    • Use a small amount of solder to not mix up the connections and prevent short circuiting.
    • In case you use a large amount of solder, use a solder wick to absorb the excess solder.
    • You can find more information on "How To Solder" here:Como soldar e dessoldar contatos
Conclusão
4 outras pessoas executaram este guia.
Bhavesh Gandhi
Membro desde: 09/26/15
585 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team 1-2, Wilson Fall 2015 Membro de IUPUI, Team 1-2, Wilson Fall 2015
IUPUI-WILSON-F15S1G2
Membros da 2
Autoria de 6 guias
6 comentários
can you fix mine contact me a jtrent238@outlook.com
jtrent238 - Responder
I am sorry jtrent238 , but i can further guide you on how you could solve the problem
Bhavesh Gandhi - Responder
If you look at step four you will see the black wire has a knot and a silver metal part. Well My wire has broken right there any advice? Please help!
Dev - Responder
Do you know where I can get the speakers from?
James Patrick - Responder
my problem exist in this area https://imgur.com/grLwOkt cant figure out how to detach the entire bud to get access to the internal wires
John - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 20
Duração total: 3,722
