Ir para o conteúdo principal
Turtle Beach Ear Force P11 Microphone Replacement
O que você precisa
  1. Turtle Beach Ear Force P11 Microphone Replacement, Microphone: passo 1, imagem 1 %32
    • Remove the microphone cover by unscrewing the screw on the front side of the microphone.
    • It is recommended to use #000 Philips head screwdriver.
  2. Turtle Beach Ear Force P11 Microphone Replacement: passo 2, imagem 1 %32
    • Use a nylon or metal spudger set to lift out the microphone.
    • Be careful lest you might break the fragile wires.
    • Always try using a plastic tool before resorting to a metal tool as shown in the picture.
  3. Turtle Beach Ear Force P11 Microphone Replacement: passo 3, imagem 1 %32
    • De-solder the microphone wires and remove the microphone.
    • Use low heat for de - soldering
    • Do not cut the white and black wires soldered to the microphone as you might reduce the length of wire required to reassemble.
  4. Turtle Beach Ear Force P11 Microphone Replacement: passo 4, imagem 1 %32
    • Solder the new microphone wires in the same position as the old one.
    • It is advisable to use a lead free solder
    • Use a small amount of solder to not mix up the connections and prevent short circuiting.
    • You can find more information on How to Solder here: Como soldar e dessoldar contatos
    • To complete reassembly replace the cover taken off in step 1.
Conclusão
Uma outra pessoa concluiu este guia.
Bhavesh Gandhi
Membro desde: 09/26/15
585 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team 1-2, Wilson Fall 2015 Membro de IUPUI, Team 1-2, Wilson Fall 2015
IUPUI-WILSON-F15S1G2
Membros da 2
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 2,006
