Ir para o conteúdo principal
Trio Stealth-10 Speaker Replacement
O que você precisa
  1. Trio Stealth-10 Speaker Replacement, Back Panel: passo 1, imagem 1 %32
    • To remove the back panel, you will need to use a plastic opening tool and slowly separate the back panel from the device.
  2. Trio Stealth-10 Speaker Replacement, Speaker: passo 2, imagem 1 %32
    • This next step will require you to solder a couple of wires off the motherboard. We recommend you get someone to help you if you are unfamiliar with soldering or use Ifixit's Soldering guide to help you.
    • Next you must solder off the wires that connect the speaker to the motherboard.
  3. Trio Stealth-10 Speaker Replacement: passo 3, imagem 1 %32
    • Next you will need to remove the two screws attached to the speaker. If you have a 54 bit Driver Kit use the Philips Head 0 (or PH 0) head to remove the two 4mm screws.
Conclusão
Uma outra pessoa concluiu este guia.
Daniel Coleman
Membro desde: 10/29/15
643 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 1-4, Miles Fall 2015 Membro de UMass Dartmouth, Team 1-4, Miles Fall 2015
UMASSD-MILES-F15S1G4
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 6
Duração total: 272
