Ir para o conteúdo principal
Trio STEALTH-9 Battery Replacement
O que você precisa
    1. Trio STEALTH-9 Battery Replacement, Back Cover: passo 1, imagem 1 %32
      • Remove the two Phillips #00 screws on the side of the tablet.
      Pergunte ao FixBot
      Comentar
    2. Trio STEALTH-9 Battery Replacement: passo 2, imagem 1 %32
      • Take one of the plastic opening tools and wedge it in the middle of the tablet, starting on the USB Port side.
      • Holding the tool in place, take one of the 6 plastic opening picks and slide it across the opening you made with the opening tool.
      Pergunte ao FixBot
      Comentar
    3. Trio STEALTH-9 Battery Replacement: passo 3, imagem 1 %32
      • Continue going around the tablet sides with the plastic pick, being sure that you are maintaining the openings you made with either your hand or the opening tool.
      • You will notice some popping as you go around with the pick. Don't worry, this is completely normal.
      Pergunte ao FixBot
      Comentar
    4. Trio STEALTH-9 Battery Replacement: passo 4, imagem 1 %32
      • Remove the back cover of the tablet to reveal the internals.
      • To replace, pinch each of the ends together until all four sides are closed.
      Pergunte ao FixBot
      Comentar
    1. Trio STEALTH-9 Battery Replacement, Battery: passo 5, imagem 1 %32
      • With the cover removed, slowly pull the electrical tape away as shown.
      Pergunte ao FixBot
      Comentar
    2. Trio STEALTH-9 Battery Replacement: passo 6, imagem 1 %32
      • Slowly pull the Battery away from the tablet frame.
      Pergunte ao FixBot
      Comentar
    3. Trio STEALTH-9 Battery Replacement: passo 7, imagem 1 %32
      • Prepare your Soldering Iron and Removal Tools.
      • Contact the iron with each of the battery leads, and pull the lead away from the board.
      • Remove any excess solder as needed.
      Pergunte ao FixBot
      Comentar
    4. Trio STEALTH-9 Battery Replacement: passo 8, imagem 1 %32
      • To replace your battery, you must reinsert the Battery leads into the Motherboard, being sure that the Red wire goes into the + (positive) terminal and the Black wire goes into the - (negative) terminal.
      • Apply heat and solder to each lead individually.
      • Remove any excess solder if flooding occurs.
      Pergunte ao FixBot
      Comentar
Conclusão
To replace the battery, you must re-solder the leads on the battery into the motherboard. You MUST make sure that the leads were in the correct order as when you started.
[deleted]
Membro desde: 01/29/15
415 Reputação
Autoria de 3 guias
1Comentário do guia
Is it possible that the wiring to the battery just became loose and I could use these same directions and reconnect or solder (or do both?) The existing battery ?
Jessie ussery - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 31
Ao todo: 1,845
