Ir para o conteúdo principal
Trio STEALTH-9 Back Cover Replacement
O que você precisa
    1. Trio STEALTH-9 Back Cover Replacement, Back Cover: passo 1, imagem 1 %32
      • Remove the two Phillips #00 screws on the side of the tablet.
      Pergunte ao FixBot
      Comentar
    2. Trio STEALTH-9 Back Cover Replacement: passo 2, imagem 1 %32
      • Take one of the plastic opening tools and wedge it in the middle of the tablet, starting on the USB Port side.
      • Holding the tool in place, take one of the 6 plastic opening picks and slide it across the opening you made with the opening tool.
      Pergunte ao FixBot
      Comentar
    3. Trio STEALTH-9 Back Cover Replacement: passo 3, imagem 1 %32
      • Continue going around the tablet sides with the plastic pick, being sure that you are maintaining the openings you made with either your hand or the opening tool.
      • You will notice some popping as you go around with the pick. Don't worry, this is completely normal.
      Pergunte ao FixBot
      Comentar
    4. Trio STEALTH-9 Back Cover Replacement: passo 4, imagem 1 %32
      • Remove the back cover of the tablet to reveal the internals.
      • To replace, pinch each of the ends together until all four sides are closed.
      Pergunte ao FixBot
      Comentar
Conclusão
To reassemble your device, follow these instructions in reverse order with your replacement cover!
Mei Liang
Membro desde: 01/29/15
228 Reputação
Autoria de 2 guias
Equipe
Clemson, Team 15-5, Shirley Winter 2015 Membro de Clemson, Team 15-5, Shirley Winter 2015
CLEM-SHIRLEY-W15S15G5
4 Membros
Autoria de 4 guias
2Comentários do guia
Tengo.una y costo tiene el.displey
eliehtmaria - Responder Compartilhar
Deseo.saber el.c
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 34
Ao todo: 1,548
